motor swap
Do you know anything about the new replacement engine? When I use to swap out engines I tried to replace wear items like a new water pump, & thermostat. New hoses, new plugs, check cap & rotor. If you see any areas of oil leaks might replace gaskets. make sure motor mounts are in good shape. of course oil & filter.
GuyWithAnOldFORD
06-13-2010 06:41 PM
jimcampbell_29
11-18-2007 07:57 PM
ray5484
10-19-2004 12:39 AM
