Carb ID question
According to the Ford parts catalog there are three possibilities.
77-78 F150-250 w/ 351M except w/ calif emissions
Tag D8PE-CVA
77-78 F150-350 w/ 351M except w/ Calif emissions
after s/n Y80,001
Tag D7TE-ATA
78 F150-350 w 351M except w/ Calif emissions
Tag D8PE-ATA
All use the same parts list (37N) and they all use the same carb kit.
Ford p/n D9PZ-9A586-L Motorcraft p/n CT-1262
Tag D8PE-CVA
after s/n Y80,001
Tag D7TE-ATA
Tag D8PE-ATA
Tag D8PE-CVA
after s/n Y80,001
Tag D7TE-ATA
Tag D8PE-ATA
Tag D8PE-CVA
after s/n Y80,001
Tag D7TE-ATA
Tag D8PE-ATA
I'm having the same issue with my Indy truck, perhaps you could tell me which kit I should use for a mid-year '79, 302/C4/2wd F-150?
My early searches turned up three different possible kits, one of which matched the kit I will need to buy for my '77 with the 400. I was thinking of buying that kit and disassembling both carbs at once to see if I should order another of the same kit, but if not I'd still be looking at a 50/50 shot. Any advice would be appreciated.
The first one is listed as
Carb tag # D9TE-BTB
1979 F100-250 w/ 302 & A/T
Uses parts list 29AW
Carb kit D9PZ-9A586-N Motorcraft # CT-1264
The second is
Carb tag # D7PE-AAA
1977 F100
1977-up F150 w/ 302 & A/T
Uses parts list 29AL
Carb kit D9PZ-9A586-G Motorcraft # CT-1258
Super old thread I know, but I need similar help and it seems that mikeo0o0o0 was on a roll helping everyone else. Someone please help, my tag is gone and I need to order the rebuild kit so I was hoping I could get the list of available carb numbers that would apply to my truck...
79 F250 4x4 351M 4spd ordered in Pittsburgh, PA. I know its the 2150 Motorcraft just need the possible part numbers. Thanks!
1979 F150/250 351M 2WD/4WD M/T w/o CA emission / Use with carb tag number: D9TE-BJB or D9TE-BNB
3 QTR FUN
03-15-2012 09:01 AM
johnny_brown
10-14-2011 07:01 PM
BlackLabel78
03-03-2010 03:31 PM
Reed_50
10-19-2009 10:46 AM
straightsix4x4
06-11-2008 10:05 PM
