Holley 1904 single barrel carb top of bowl problem.. - Ford Truck Enthusiasts Forums
Old 10-28-2013, 10:35 PM
Mando77ford Mando77ford is offline
Mando77ford is starting off with a positive reputation.
I have a 1957 F-100 with the 223 I-6 motor and Holley single barrel carb. My question is
On the top of the float bowl there is a small opening that looks like a raised hole with two small openings on the side. Inside that hole there looks to be some type of plug.
Well my plug is no longer in that hole and it is pumping a steady stream of gas out of it. I looked at a bunch of rebuild kits but none of them look like they come with any type of plug for that.
What do I do? Is there a place to buy that plug or do I just make one with some epoxy? Any info or fixes will be greatly appreciated.
Old 10-28-2013, 10:41 PM
Maltman's Avatar
Maltman Maltman is offline
Maltman has a very good reputation on FTE.Maltman has a very good reputation on FTE.Maltman has a very good reputation on FTE.Maltman has a very good reputation on FTE.
That is actually a vent. Shouldn't be plugged, needle may be stuck open or float not set correctly. When carb is adjusted correctly no fuel should pour out. I hope this helps.
Joe
Old 10-29-2013, 12:36 AM
I know I can't close it completely off but it used to have a cream colored plug in the top of the vent hole. I looked at about a dozen of them in pictures they all have that same plug in the hole, or at least in the top of the hole above the two small vent holes, on my carb this cream colored filler is missing, and the gas did not start leaking until that blew out...
Could this be the reason it's leaking gas from that hole or do u think that my problem is internal with a stuck float?
Old 10-29-2013, 12:25 PM
Maltman's Avatar
I haven't seen the top open, but I am fairly new to these myself. I have rebuilt 2 and haven't seen the side vents plugged up. I'm sure someone will be by with more knowledge than me to help you out. You can search 1904 in the straight six forum, or Mikes Carburetor Parts is a great source for info, always responds to emails as well.
Holley 1904
Holley 1904 Carburetor Parts
Rebuild sitting Holley Single barrel? mOROTBREATH 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 09-18-2016 11:28 PM
Holley 1904 Leaking Problem Joshua1960 1957 - 1960 F100 & Larger F-Series Trucks 13 07-08-2016 07:06 PM
Bought a junkyard holley carburetor- dont know what rebuild kit to buy. d250 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 10 07-14-2012 01:32 AM
holley 1904 carb robertr2D 1961 - 1966 F-100 & Larger F-Series Trucks 8 01-06-2012 09:52 AM
Holley Carb - 1850(4160) Flooding... North42g Fuel Injection, Carburetion & Fuel System 10 08-20-2011 07:22 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
