52 Flywheel - Ford Truck Enthusiasts Forums
52 Flywheel
Old 10-28-2013, 09:10 PM
Artf0rm Artf0rm is offline
Artf0rm is starting off with a positive reputation.
52 Flywheel
I have been going through the process of getting things mechanically sound while I work on the cosmetics of the 52 I just picked up. It's a 215 straight 6 with a three on the tree (light duty). The long and short of it is that it shakes at low rpms either in reverse or first. When I picked it up the PO said that when he did the clutch a year ago he didn't turn the flywheel because he was worried that it could have been turned before and didn't know the tolerances. This leads me to a few questions:
- Do I have to take the engine out to replace the flywheel. The shop manual says that to work on the flywheel I should remove the engine.
- Where in the world can I get a new flywheel I haven't found anything but flywheel ring gears available. Whats the deal with that?
- How do I go about figuring out what the tolerances are for a flywheel?
Hopefully these aren't too stupid of questions. This is my first resto on a truck after building a few bikes.
Old 10-28-2013, 10:46 PM
fixnair's Avatar
fixnair fixnair is offline
fixnair has a very good reputation on FTE.fixnair has a very good reputation on FTE.fixnair has a very good reputation on FTE.fixnair has a very good reputation on FTE.
Your flywheel would have to be really worn to be worried about tolerances. Resurfacing a flywheel only removes marbe .050" and you wouldn't need be worried unless you had to remove maybe .300".
To get the flywheel out you can leave the engine in the frame but you would have to remove the trans, clutch & starter and then the flywheel.
Old 10-28-2013, 10:54 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is offline
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
Are you saying it shudders or chatters when you are releasing the clutch? or is it shaking with the clutch all the way out at low RPM? Check motor and trans mounts before you go digging into it.
Old 10-28-2013, 11:10 PM
Quote:
It shudders when I let it out. Once you get it in gear and start to accelerate it doesn't do it at all.
Old 10-28-2013, 11:23 PM
ALBUQ F-1's Avatar
postin' fool
That's typically caused by a glazed surface on the flywheel and/or pressure plate. Could also be from oil on the surfaces that has burned into a sticky mess. Pull the trans, then the clutch and see what it needs. You pull the trans up thru the access in the floor of the cab (remove the seat and drain trans first).
TMeyer ZF5 Adaptor For 335 Series Engines Gary Lewis 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 36 08-04-2015 04:21 AM
torque converter AOD papabills54 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 11-14-2014 08:55 PM
Solid flywheel conversion in the future FordOwnerJoey Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 10-05-2013 07:34 PM
Flywheel/Clutch problems... ATC Crazy 1973 - 1979 F-100 & Larger F-Series Trucks 9 05-13-2013 02:14 PM
Smallblock flywheel differences rosentr Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 2 02-21-2003 10:35 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
