300 Carburetor - Ford Truck Enthusiasts Forums
300 Carburetor
Old 10-28-2013, 09:41 PM
cstephens cstephens is offline
cstephens is starting off with a positive reputation.
300 Carburetor
Just curious. My '83 F-100 has the original style reman carb (The 1 bbl Carter YF, I think, is what it is, someone correct me if I'm wrong). My question is: what new or aftermarket carb could I get to get better fuel economy? Or more power? I'm really not sure what direction I want to go, yet. If you find some carbs that would be good for either use, post the link for me. Or better yet, if you could post some links for both, just do that. Keep all the options open Also, on a carb, for fuel economy, is it better to stick with a 1 bbl or go to something else? I'm new to working on vehicles, so any info about carbs would be great, really.
EDIT:
Holley 0-8007 - Holley 390 cfm Vacuum Secondary 4-bbl Carburetor
Would this carb work? What would be the benefits/drawbacks?
Old 10-29-2013, 10:39 AM
1986F150six 1986F150six is offline
1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold
Many of our forum members lean toward the use of a 2 or 4 barrel carburetor with either an Offenhauser or Clifford aluminum intake with regard to enhancing performance. They will also tell you about using the exhaust manifolds from a 1987-1996 fuel injected 4.9L, a H.D. exhaust manifold [used for large trucks 1965(?)-mid 1970s] or tubular headers. All of these are freer flowing than the stock "log" manifolds.
My conservative opinion is that if one REALLY wants to get the best mileage [rather than greater performance], you should stick with the original carburetor and embrace this engine for what it is... tough, economical, easy to service and long-lasting. Learn to drive economically and perhaps invest in an inexpensive vacuum gauge to help you learn the sweet spot of this engine.
If you really want performance, a V8 is the less expensive way to go.
By the way, I love these engines and do not want a V8.
Carb hunting again. AbandonedBronco Ford Inline Six, 200, 250, 4.9L / 300 17 01-16-2015 02:09 PM
Need help finding new carb for 300. McYondan Fuel Injection, Carburetion & Fuel System 3 03-03-2014 11:59 PM
Carter YF 1BBL Carb cstephens Ford Inline Six, 200, 250, 4.9L / 300 6 12-01-2013 02:36 PM
1 bbl on 4 bbl intake 1983F1503004x4 Ford Inline Six, 200, 250, 4.9L / 300 2 01-08-2012 11:25 AM
3 carbs to choose from, opinions please kadrocker Fuel Injection, Carburetion & Fuel System 10 01-01-2010 09:26 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
