Painting interior
Old 10-28-2013, 10:25 AM
FordYoungGun35's Avatar
FordYoungGun35
FordYoungGun35 is offline
Painting interior
96 F-150 XLT single cab... I'm trying to make everything black, carpet, headliner, dash, trim, glove box, except for the door panels, that would be hard with all of the different materials..
I wanna know what I need to use and do as far as prep work to paint the dash and glove box and all that good stuff...
Right now my dash and everything is plasti-dipped.. Doesn't really look to bad but it's a PITA to clean, and when it gets knicked or scratched it starts peeling away...
I might just buy a cloth dashpad from LMC (anyone had one) and lastly LMC offers a headliner that has speakers and a storage compartment Truck Parts and Truck Accessories and what are they referring to when they say with and without factory headliner?
As most of you know thru the "F-150 w/Blackeye comeback" thread I'm rebuilding/restoring my truck so right now it's on blocks, so this is perfect time for me to do this as it won't be driven for awhile..
Thanks in advance for the help, Logan "FYG35"
Old 10-28-2013, 11:18 AM
Bob Gervais's Avatar
Bob Gervais
Bob Gervais is offline
Use the rustoleum undercoat on it!
Seriously though, SEM offers a great line of interior spray paint. I used it on my Crown Vic and it worked and held up great. Minimal prep. I wiped all my stuff down with denatured alcohol and sprayed it.
Old 10-28-2013, 11:29 AM
FordYoungGun35
I'm at Home Depot now, bout to goto packs... Does rustomelum make
Anything that will work?
Old 10-28-2013, 12:03 PM
FordYoungGun35
I've got some rustoleum vinyl/fabric paint at home it says its for dashboards, seats, and carpet, and ive got another can the is specifally for plastic...
Old 10-28-2013, 12:06 PM
Bob Gervais
I've never used rustoleum stuff for interiors. I tried duplicolor once and it didn't hold up too well.
I got SEM at my local NAPA. They had to order the color I wanted, but it only took a day to get it in. A little more expensive, but worth it.
Old 10-28-2013, 02:24 PM
xmontex4's Avatar
xmontex4
xmontex4 is offline
'm doing the same thing and I have always used color bond paint. All i did was clean the parts and then spray them. Some arts like the kick panels the paint doesn't stick to though so it would be beneficial to first clean the parts with soapy water and then spray them with duplicolor adhesion promoter (2 coats) and then 3-4 coats of your colored paint. Let it dry for a half hour between each coat and you'll be golden. I pulled down my headliner and got a suede headliner kit off Ebay in black and just recovered it. For the visors ill probably just buy LMC black ones and for the carpet jeffs bronco graveyard has replacement carpets for $175 in many colors.
Old 10-28-2013, 04:10 PM
FordTruckfan89's Avatar
FordTruckfan89
FordTruckfan89 is offline
painting plastic is all about the prep. ive been told to use windex, the ammonia does something to clean the plastic, and wipe with rubbing alcohol, follow with a couple coats of adhesion promoter, plastic and fabric paint, and give it a few days to fully cure. I smothered it then in armorall. I did not sand the SD dome light I painted, since the plastic was not chalked. if you can buy something in black, it may work better, but good plastic can be painted, and it will last a while when done correctly.
Old 10-28-2013, 04:19 PM
TheGageinator's Avatar
TheGageinator
TheGageinator is offline
Post pics when you can! i'd like to see how it turns out / wears over time...
Old 10-28-2013, 04:43 PM
xmontex4's Avatar
xmontex4
xmontex4 is offline
Ill post a pic when I repaint my peeling pieces next weekend. Wear isnt so bad I painted my 08 console in my SD 2 years ago snd it hasnt worn off yet thst was just 3 coats of paint no promoter.
Old 10-28-2013, 05:26 PM
FordYoungGun35
I just took some pics of my interior now.. Like I said it has plasti-dip on it now, and honestly it's not bad but I just want better..
do remember that my carpet is out as well as my bench seat lol
http://i1294.photobucket.com/albums/...psc42c2ed8.jpg
you can see my pillar gauges here
http://i1294.photobucket.com/albums/...ps1acc65e1.jpg
and here's my pristine door panels lol
http://i1294.photobucket.com/albums/...psd74c095c.jpg
So my kick panels can I just wipe them down with alcohol and spray em? do I HAVE to have that adhesive?
Old 10-28-2013, 06:00 PM
xmontex4's Avatar
xmontex4
xmontex4 is offline
That looks really good IMO. Personally use the ashesion promoter on everything 3/4 of my parts didnt stick and peel easy. Its an easy way to gaurentee that it will stick for only an extra hour of your time.
Old 10-28-2013, 06:54 PM
FordYoungGun35
yah looking at my interior I forgot I peeled it off of my glove box and I think it looks good as it is right now, I just need to re do it all with actual paint and do it right.. cause all of my a pillar trim is grey and the trim around the headliner is grey too, so I think that will make my black headliner and black carpet pop
Old 10-28-2013, 07:05 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
Dont waist your time on the seat or carpet, it will just come right off those
I would replace your cracked dash pad while you are "painting"
Old 10-28-2013, 07:10 PM
FordYoungGun35
I bought new carpet, and I had my seat reuppostered, and What do you mean by "painting"... Am I not doing good by you?
Old 10-28-2013, 07:13 PM
Diesel_Brad
It is not paint. It is vinyl dye
Quick Reply: Painting interior
