Speedometer will not work, please help. - Ford Truck Enthusiasts Forums
Old 10-27-2013, 10:16 PM
Swoop03's Avatar
Swoop03 Swoop03 is offline
Swoop03 is starting off with a positive reputation.
The speedo in my 88 f250 quit working all together now.
Before it would bounce up and down but when I pushed in the clutch, brake or gas it would drop down to nothing. I changed the speedo gear out and it worked for a little bit but was still floating a 15mph range. Then it went straight back the what it was doing before and now it doesn't even flicker.
I've changed the gear out that goes in the transfer case.
The cable spins freely and when one end moves the other follows, it's good.
I know the cluster is good, but in my truck only the speedo doesn't work. Tach and everything else are fine. It's something down along the mechanical speedo system. The speedometer moves works properly when the input is spun.
What else is there to check and replace, I'm stumped. Is it possible the worm gear in my t-case is bad? Or whatever spins it? Should I try a new cable and see if that makes a difference? Any help or advice would be greatly appreciated.
Old 10-28-2013, 06:15 AM
1970something's Avatar
1970something 1970something is offline
1970something is starting off with a positive reputation.
if you spin the cable end that goes into the transfer case and the gauge moves, that leaves either the gear on the cable end or the gear in the case that is bad.
Old 10-28-2013, 08:05 PM
Swoop03's Avatar
Ok i honestly didn't think of that. I'll try that, and if its in the transfer case would it be easier to buy a rebuild kit or something or just get a new one? It's a BW 13-56 i'm pretty sure. I imagine it's difficult to rebuilt something like that not to mention expensive. Maybe I'll head to my local junk man and see if he has a ford out there with one and i'll just do him a part for part swap.
Lube for Speedometer? KsHighboy 1967 - 1972 F-100 & Larger F-Series Trucks 12 01-26-2017 09:23 PM
np435 speedometer gear detent/hold/retainer f-250.4x4.390 1973 - 1979 F-100 & Larger F-Series Trucks 2 07-22-2015 04:12 PM
Speedometer doesn't work... overhaulin 1987 - 1996 F150 & Larger F-Series Trucks 25 07-15-2014 01:37 PM
1990 Speedo Not Working Squarebody 1987 - 1996 F150 & Larger F-Series Trucks 4 10-22-2013 01:16 AM
Speedometer problems limeyellowfellow 1967 - 1972 F-100 & Larger F-Series Trucks 3 05-15-2012 09:26 AM
Tags
1988, 4x4, doesn't, f250, speedometer, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
