huge problem about to light this truck on fire - Ford Truck Enthusiasts Forums
Old 10-27-2013, 08:09 PM
biggyfan1's Avatar
biggyfan1 biggyfan1 is offline
biggyfan1 is starting off with a positive reputation.
guys I have gone to 3 fuel pumps in the last 48 hours. I replaced the carburetor 3 fuel pumps all soft fuel lines gas tank fuel sending unit. So basically the entire fuel system. The truck will run for about 5 to 10 minutes and then the pumps will go bad. I went through to mechanical fuel pumps and decided to go with electric fuel pump today I install the electric fuel pump drove 5 miles this pump just went out. What in God's name could be happening
Old 10-27-2013, 08:19 PM
1972RedNeck's Avatar
1972RedNeck 1972RedNeck is offline
1972RedNeck has a good reputation on FTE.1972RedNeck has a good reputation on FTE.
Bad fuel??
Old 10-27-2013, 08:21 PM
biggyfan1's Avatar
no the fuel is new. the filter is clean it has a new filter on the new sending unit.
Old 10-27-2013, 08:23 PM
VocaTexas VocaTexas is offline
VocaTexas is gaining momentum as a positive member of FTE.VocaTexas is gaining momentum as a positive member of FTE.
Year, model, engine, etc. would be helpful info. Where did you buy the pumps?
With no more information, I would say you have a VERY dirty fuel tank. I've cleaned them out by taking them out, draining the liquid out of them, and then putting either a short length of small chain or a couple of hands full of clean gravel in the tank and shaking the crap out of it. Turn the tank to clean all internal surfaces, dump whatever came loose out and repeat until clean.
Old 10-27-2013, 08:28 PM
mikeo0o0o0's Avatar
mikeo0o0o0 mikeo0o0o0 is offline
mikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud of
You sure it's a fuel problem?
What trouble shooting did you do?
Old 10-27-2013, 08:33 PM
biggyfan1's Avatar
again guys read my post. Fuel tank new carburetor new soft fuel lines new fuel sending unit new 3 new fuel pumps gone through fuel filter after sending it new screen on new sending unit new gas from several on 2 days ago new
biggyfan1's Avatar
my truck is in 1974 f-100
Laser_Target Laser_Target is offline
Laser_Target is starting off with a positive reputation.
Electric pump shorting to ground and taking a big enough draw to kill its self(electrical and lights go dim before it dies)? Fuel pump have a thermal relief that kills the pump if it gets hot? What trouble shooting did you do to figure the pump is bad rather than the wiring to it?
After all that I'd burn it.
Old 10-27-2013, 08:34 PM
fmc400's Avatar
fmc400 fmc400 is offline
MSEE
fmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud of
Quote:
How about you use some punctuation and answer these folk's questions sans attitude? They're only trying to help.
Old 10-27-2013, 08:37 PM
biggyfan1's Avatar
I'm on the side of the road cold as hell.
Old 10-27-2013, 08:39 PM
JWC 3's Avatar
JWC 3 JWC 3 is offline
JWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputation
How is your tank vented ? I had a Datsun ( OK yes I'm older than some here ) The fuel tank vent got plugged ! It took a bit to figure out . Run a while , run out of fuel . new pump , that'l fix er . Nope ... finally while trying to fix it I pulled the gas cap . Almost wouldn't come off ! Vacuum had it sucked tight ! Drilled a small hole , good to go . Just a thought !
Old 10-27-2013, 08:40 PM
mikeo0o0o0's Avatar
Like I said, are you sure it's a fuel problem. Sounds like you've eliminated the possibilities so I would suspect the problem is elsewhere.
When the truck dies, what does it do? Just quit, sputter and pop, surge?
Have you checked for spark when it dies?
Old 10-27-2013, 08:48 PM
biggyfan1's Avatar
If I blow in my gas tank filler inlet and pressurize the tank I can hear my breather valve breathing. Also with the tank pressurized fuel shoots out of the fuel line that hooks in to the carb inlet. If I blow on the fuel line back the other way from carb to tank the gas goes right back in to tank with no blockage.
Old 10-27-2013, 08:51 PM
biggyfan1's Avatar
The truck dies. The glass fuel filter goes empty. The new pump only makes a clicking sound when I turn it on and does not pump. The 2 mech pumps just went bad and after a test with a vacuum/pressure gauge they pumped 0 psi.
Old 10-27-2013, 08:54 PM
biggyfan1's Avatar
JWC3 I think your going to be right. I hear the vent at the top of the tank push air out but maybe it doesn't let air in. It is the only thing not new.
Fuel Pump Questions tlb 1948 - 1956 F1, F100 & Larger F-Series Trucks 13 05-28-2016 12:19 PM
No start after fuel pump replacement 2002exPSD 1994.5 - 1997 7.3L Power Stroke Diesel 81 08-18-2011 10:48 AM
No start, fuel problem, no power to pump Powerstroke-7.3 1987 - 1996 F150 & Larger F-Series Trucks 13 12-29-2009 02:45 PM
Fuel Pump jtttj 1999 to 2016 Super Duty 3 07-05-2008 09:03 PM
1960 223 fuel pump F250racer 1948 - 1956 F1, F100 & Larger F-Series Trucks 11 06-26-2008 10:15 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
