huge problem about to light this truck on fire - Page 4 - Ford Truck Enthusiasts Forums
  #46
Old 10-28-2013, 10:17 PM
biggyfan1's Avatar
biggyfan1 biggyfan1 is offline
biggyfan1 is starting off with a positive reputation.
Might take a hammer to it lol. Its one of those problems you know?
  #47
Old 10-28-2013, 10:28 PM
VocaTexas VocaTexas is offline
VocaTexas is gaining momentum as a positive member of FTE.VocaTexas is gaining momentum as a positive member of FTE.
There really isn't any problem with fuel pumps with the integrated fuel filter. My 460 has one on it. However, I was having fuel delivery problems and finally figured out it was vapor lock. The lower radiator hose was in contact with the fuel filter canister. When the engine warmed up it would cause the fuel in the canister to boil, and no fuel made it to the carb. I had fuel from the tank to the pump, though.
You might check and make sure your fuel lines are clear of radiator hoses and exhaust manifolds, etc. Check for anything that could be causing a vapor lock condition.
  #48
Old 10-31-2013, 08:00 PM
biggyfan1's Avatar
Update
Ok so I installed mechanical pump # 3 and also replaced all the rubber lines again just to be safe. I dropped the take made sure the tank was clean again and it was. The only bad thing was the little screen on the sending unit was off because of the air I blew threw the lines to see if they were clear. The sending unit filter was clean though. I also drilled out the gas tank vent and took the little bobber out so I know its breathing good. A new fuel cap was also installed. The truck seems to be running go today so for now she is fixed. I never really figured out what the problem was but it seems to be good for right now.
  #49
Old 10-31-2013, 08:26 PM
arctic y block's Avatar
arctic y block arctic y block is online now
arctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputation
Let us know if it comes back M8. It's all good info for the next guy.
2000 E-350 5.4L Removing the Fuel Pump mikey112383 1968-2013 Full Size Vans 5 03-08-2015 08:15 PM
No start after fuel pump replacement 2002exPSD 1994.5 - 1997 7.3L Power Stroke Diesel 81 08-18-2011 11:48 AM
Fuel Pump jtttj 1999 to 2016 Super Duty 3 07-05-2008 10:03 PM
1960 223 fuel pump F250racer 1948 - 1956 F1, F100 & Larger F-Series Trucks 11 06-26-2008 11:15 PM
93 F150 fuel pump my93 Fuel Injection, Carburetion & Fuel System 5 11-07-2004 08:25 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
