huge problem about to light this truck on fire - Page 2 - Ford Truck Enthusiasts Forums
Old 10-27-2013, 09:57 PM
JWC 3's Avatar
JWC 3 JWC 3 is offline
JWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputation
Quote:
Originally Posted by biggyfan1 View Post
JWC3 I think your going to be right. I hear the vent at the top of the tank push air out but maybe it doesn't let air in. It is the only thing not new.
Try leaving the gas cap off for a bit , see how she does . Best of luck !
Old 10-27-2013, 10:00 PM
Tofan's Avatar
Tofan Tofan is offline
Tofan is a name known to allTofan is a name known to allTofan is a name known to allTofan is a name known to allTofan is a name known to allTofan is a name known to all
I would probably get the truck towed since you said your on the side of the road. Do you have a daily driver? I understand you like working on your truck, but posting on here that your stranded on the side of the road and it's cold doesn't sound so good.
Old 10-27-2013, 10:04 PM
JWC 3's Avatar
One more thought . My 78 has metal lines from front to the tank . rubber at the tank . AND a rubber union along the frame ! Years ago I had a problem with it sucking air from cracks in the rubber . It did not leak fuel , just sucked air . Just a thought !
Old 10-27-2013, 11:20 PM
biggyfan1's Avatar
biggyfan1 biggyfan1 is offline
biggyfan1 is starting off with a positive reputation.
well I just got it towed home. I'm going to go ahead and change all the rubber fuel lines again tomorrow just because I have about 5 feet of fuel line. I might also drop the tank and by a different breather because the breather on the tank is the only old part in the entire fuel system including the gas cap which is also old.
Old 10-28-2013, 12:11 AM
1958 Ford F250's Avatar
1958 Ford F250 1958 Ford F250 is offline
1958 Ford F250 is starting off with a positive reputation.
Smile Fuel Pump
guys I have gone to 3 fuel pumps in the last 48 hours. I replaced the carburetor 3 fuel pumps all soft fuel lines gas tank fuel sending unit. So basically the entire fuel system. The truck will run for about 5 to 10 minutes and then the pumps will go bad. I went through to mechanical fuel pumps and decided to go with electric fuel pump today I install the electric fuel pump drove 5 miles this pump just went out. What in God's name could be happening
Hi, I agree with (JWC 3) That happen to my 1958 F250 after getting it towed home and lots of Frustration, it all boiled down to a VENTED GAS CAP. So try looking into that !! GOOD LUCK
Old 10-28-2013, 12:25 AM
77&79F250's Avatar
77&79F250 77&79F250 is offline
Used OEM parts guy
77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future
Since you are all up in there dropping the tank again and all, you might as well at least blow out the hard line that run down the dvrs side of the frame.
Yes get a new tank top roll over vent for it, filler vent line clear? Try a vented gas cap. Are you running a fuse on the elec pump to protect it?
Get some extra gas on hand since it sounds like it will not have any in the lines if you do torch it, lol JK. Hang in there you will fit it tomorrow, let us know what it was.
Cracked fuel lines sometimes do not leak, but let air in.
Old 10-28-2013, 12:30 AM
biggyfan1's Avatar
when I put the electric fuel pump in yesterday I blew out the fuel lines into a bucket and it was totally clear. I've owned the truck about 5 months now and the same fuel lines have been working fine.
Old 10-28-2013, 12:45 AM
77&79F250's Avatar
Used OEM parts guy
Maybe try getting your mechanical fuel pumps from a different parts store and try a different manufacture, maybe Dorman....Spector...Look up Rock Auto they have great prices.
Try getting it to run off a stock mech pump and out of a gas jug first....
Old 10-28-2013, 12:51 AM
biggyfan1's Avatar
both mechanical fuel pumps that I bought were from Napa. The electrical one that I just replaced the mechanical ones with was made by Mr Gasket. Probably not the best fuel pump but I was broken down and the parts store was right up the street and that's all they had as far as universal in line pumps. I might go back to mechanical once I fix this ventilation problem if that's what it is. I just find it kind of odd when I pressurize my gas tank I can hear the vent on top of the gas tank letting out air. is that vent/valve on top of the tank to let air in or out? I'm assuming it works kinda like a PCV valve. Maybe I should hook the vacuum up to it and put negative pressure and see if I hear the same noise going the other way.either way I'm dropping the tank tomorrow.
Old 10-28-2013, 01:36 AM
biggyfan1's Avatar
ok so I was just testing some things so maybe you guys can tell me what you think. The gas cap has a little hole in it where im guessing is the valve. So I put my air hose to it and it blows air out and it blows it out at a decent rate. Then I put my darn lips on that bad boy and sucked lol I know lol I sucked and well it breaths. Then I once again pressurized the gas tank with my air hose threw the fuel line that hooks to the carb. The air goes all the way to the tank and I hear the bubbles coming from the sending unit then I hear the gas cap letting the air out right away. Either way tomorrow im buying a new gas cap just to say its new. If I get a new cap that breaths both ways then would I really need a gas tank vent that goes on the top? im really not trying to drop this tank again.
Old 10-28-2013, 04:51 AM
montana_highboy montana_highboy is offline
montana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud of
You need to stop blowing into tanks....
Old 10-28-2013, 09:02 AM
77&79F250's Avatar
Used OEM parts guy
Go back to the beginning, what did you do last "working on" wise to the truck before it started having this issue?
Or what has changed or has be adjusted incorrectly?
  #28
Old 10-28-2013, 12:11 PM
biggyfan1's Avatar
well so far today I exchange the fuel pump. And I bought a new gas cap. The new gas cap seems like it breathes even less than the old one but it's one more piece I can say is new the case I have this issue again. I still might drop the tank test event at the top of the gas tank. Also while reading instructions on the sand line electric fuel pump it says the place it within 12 inches of the fuel tank do you think that that really matters?
  #29
Old 10-28-2013, 12:50 PM
biggyfan1's Avatar
so I hook up a new fuel pump and I'm draining the gas tank. I have the fuel pump hooked up where it was before, instead of having it pumping into the carburetor I have the hose inside some empty gas tanks. so far I have successfully pumped out 9 gallons of gas with no issues. The truck failed in 3 to 5 miles before and that's no where near 9 gallons. I pumped the first 4 gallons of gas with the old fashioned Canandaigua it did just fine. Put the new cap on and it's still fine. what I do notice is when I hook the fuel line to the carburetor and turn the pump on the sound of the motor drastically changes because it's no longer free flowing its building up pressure do you think that's putting too much on my pumps for some reason? It's almost as if the pumps are pumping but the carburetors not pulling in enough fuel and it's tearing diaphragms and burning pumps? What do you think just a thought
  #30
Old 10-28-2013, 01:08 PM
MBDiagMan's Avatar
MBDiagMan MBDiagMan is offline
MBDiagMan is gaining momentum as a positive member of FTE.
Have you checked to make sure that the tank is venting okay? Run it with a vented fuel cap and see if it will run more than 10 minutes.
Is there a screen on the pickup in the tank? If so, it might be plugged up allowing fuel to gradually soak through it letting it start and run a little while, but I don't think that would cause what you're experiencing, but I'm trying to offer some thoughts that might lead you to a solution.
Hope this helps.
Fuel Pump Questions tlb 1948 - 1956 F1, F100 & Larger F-Series Trucks 13 05-28-2016 01:19 PM
Electric fuel conversion in a 2000 kbarbee95 1999 - 2003 7.3L Power Stroke Diesel 4 08-18-2015 07:33 PM
2000 E-350 5.4L Removing the Fuel Pump mikey112383 1968-2013 Full Size Vans 5 03-08-2015 08:15 PM
Neighbors 2000 V10 possiable fuel pump electrical issue Monster-4 1999 to 2016 Super Duty 3 08-29-2013 10:41 PM
86 Electric Fuel Pump Problem Mustang Mover 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 43 09-19-2012 07:37 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
