'79 Gauge wiring, please help! - Ford Truck Enthusiasts Forums
Old 10-27-2013, 08:46 PM
bryanmartin's Avatar
bryanmartin bryanmartin is offline
bryanmartin is starting off with a positive reputation.
Hi everyone,
I'm replacing my wiring harness in my '79 with a Painless 12-circuit harness. The problem I'm running into is that the instructions are written for separate gauges, not the printed circuit type like ours. I've traced out all of the wires and what they go to on the printed circuit, but I can't figure out how the gauges gets their power.
Here's what I have:
Blu/Red = Instrument lights
Yel/Blk = Alternator gauge
Red/Org = Alternator gauge
Grn/Wht = Left turn indicator light
Blk = Gauge ground
Org = Fuel sender
Wht/Red = Oil pressure gauge
Red/Yel = Brake warning light
Ppl/Wht = Brake warning light
Pnk = Seatbelt warning light
Grn/Blk = High beam indicator light
Wht/Blu = Right turn indicator light
Red/Wht = Temp gauge
Blk = Light ground
According to the Ford wiring diagram there should also be a Blu/Grn and a Red/Grn wire going to the gauges, but I don't have those. Are the gauges and lights powered by the sending unit wire, or is there separate power coming in somewhere? The Painless harness has wires for the sending units, and a separate power wire that I'm supposed to jumper to each gauge. That doesn't work with the printed circuit. Please don't just send me a copy of the standard Haynes/Chilton wiring diagram, I have those and they aren't helping.
Thanks!
Old 10-27-2013, 08:56 PM
mikeo0o0o0's Avatar
mikeo0o0o0 mikeo0o0o0 is offline
mikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud of
Quote:
Originally Posted by bryanmartin View Post
Hi everyone,
Here's what I have:
Blk = Gauge ground
Org = Fuel sender
Blk = Light ground
Thanks!
There should be a black w/ green stripe resistor wire that is goes into the pc plug on the back of the instrument cluster. This powers the ICVR on the back of the cluster. This powers the instruments. The sending units don't power the gauges, they ground the gauges.
The black wire w/ green stripe will say "resistor wire-do not cut or splice" it should have 8-9 ohms resistance.
This wire will go from the plug on the instrument cluster to a splice behind the cluster where it connects with two other wires, also black/green, one goes to the ignition switch, the other goes to the fuse block. These two wires are regular wires not resistor.
Old 10-27-2013, 08:58 PM
You are awesome!
Old 10-27-2013, 10:37 PM
mikeo0o0o0's Avatar
Thanks, happy to help.
2001 EX 6 disc / RISC no dvd stereo wiring help Strummerpete Excursion - King of SUVs 4 03-19-2014 08:03 PM
'79 Gauge wiring, please help! bryanmartin 1978 - 1996 Big Bronco 2 11-03-2013 09:15 PM
99 7.3 in a 79 F250 79OldBone Engine Swaps 6 07-16-2012 11:28 PM
How alternator should be connected? gmacuajo Electrical Systems/Wiring 5 04-23-2012 08:12 AM
Computer Pinout Diagram? 79OldBone 1994.5 - 1997 7.3L Power Stroke Diesel 7 10-06-2011 08:41 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
