'79 Gauge wiring, please help! - Ford Truck Enthusiasts Forums
Old 10-27-2013, 07:45 PM
bryanmartin's Avatar
bryanmartin bryanmartin is offline
bryanmartin is starting off with a positive reputation.
Hi everyone,
I'm replacing my wiring harness in my '79 Bronco with a Painless 12-circuit harness. The problem I'm running into is that the instructions are written for separate gauges, not the printed circuit type like ours. I've traced out all of the wires and what they go to on the printed circuit, but I can't figure out how the gauges gets their power.
Here's what I have:
Blu/Red = Instrument lights
Yel/Blk = Alternator gauge
Red/Org = Alternator gauge
Grn/Wht = Left turn indicator light
Blk = Gauge ground
Org = Fuel sender
Wht/Red = Oil pressure gauge
Red/Yel = Brake warning light
Ppl/Wht = Brake warning light
Pnk = Seatbelt warning light
Grn/Blk = High beam indicator light
Wht/Blu = Right turn indicator light
Red/Wht = Temp gauge
Blk = Light ground
According to the Ford wiring diagram there should also be a Blu/Grn and a Red/Grn wire going to the gauges, but I don't have those. Are the gauges and lights powered by the sending unit wire, or is there separate power coming in somewhere? The Painless harness has wires for the sending units, and a separate power wire that I'm supposed to jumper to each gauge. That doesn't work with the printed circuit. Please don't just send me a copy of the standard Haynes/Chilton wiring diagram, I have those and they aren't helping.
Thanks!
Old 10-28-2013, 02:35 PM
Encho's Avatar
Encho Encho is offline
The Southernmost Mod
Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.
I'm sorry I can't be of any help, I'll just take your thread up, maybe someone else knows. You could also try posting your question here: 1973 - 1979 F-100 & Larger F-Series Trucks - Ford Truck Enthusiasts Forums it might get more answers.
Old 11-03-2013, 08:15 PM
g_k50 g_k50 is offline
g_k50 is gaining momentum as a positive member of FTE.g_k50 is gaining momentum as a positive member of FTE.
gauge is part of the circuit. It completes the circuit as the power goes to ground.
For example, the float in the gas tank has a variable resistance, the gauge goes up and down depending on the resistance. The power comes from the sending unit thru the gauge then to ground.
2001 EX 6 disc / RISC no dvd stereo wiring help Strummerpete Excursion - King of SUVs 4 03-19-2014 07:03 PM
'79 Gauge wiring, please help! bryanmartin 1973 - 1979 F-100 & Larger F-Series Trucks 3 10-27-2013 09:37 PM
99 7.3 in a 79 F250 79OldBone Engine Swaps 6 07-16-2012 10:28 PM
Computer Pinout Diagram? 79OldBone 1994.5 - 1997 7.3L Power Stroke Diesel 7 10-06-2011 07:41 AM
94 ClubWagon Wire harness identify help!!! IntrepidCUB 1968-2013 Full Size Vans 1 06-29-2007 09:00 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
