header qustion
header qustion
i just bought my self some hedman headers and a high flow cat to finish off my exuast system. I have heard some things about when you install headers about your truck running rich or lean. Can someone tell me is this is true or not and if it is could you tell me how to prevent it. Also i am wondering how to put to o2 sencer back on because i am replacing both cats with a high flow one. I was wondering if i could just drill a hole in the pipe and reinstall it. I really dont want to do this rong because if my engine blows i am $*!& out of luck. Thanks for your help
Rudy Jones
Rudy Jones
header qustion
W/o the o2 sensor, it will run rich.
Primary rig is:
95' F-150 XLT 4x4, 302, 5 spd, MSD 6A, Sunroof, and some 32" BFG Muds .
Pictures are in!!
Then theres:
99' Mustang GT 4.6L
88' F-250 Superduty 4x4 351/c6
95' Mercury Cougar 4.6L V-8
80' E-350 300/6 with a
3 spd column shifter. Top speed is 65mph, Go Baby Go!
Primary rig is:
Pictures are in!!
Then theres:
99' Mustang GT 4.6L
header qustion
Are you going with two cats for true duals, If so the best place for the O2 sensor is in the H pipe, any good muffler shop can install the sensor in the exhaust just about any were. If you going to combine the headers together into one High Flow cat, the O2 sensor would go at that point in the exhuast system. Be sure the O2 sensor can read the total engine exhaust. Or you rig will run rich with horrible fuel milage, and not that great of performance.
The H pipe is just a piece of pipe crossing over between the headers, the muffler shop will have scrape pipe to use for the H pipe.
