1975 F250 4x4 Crew Cab Air Cooled Diesel Found! - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 10-28-2013, 02:53 AM
rogue40's Avatar
rogue40 rogue40 is offline
rogue40 has a great reputation on FTE.rogue40 has a great reputation on FTE.rogue40 has a great reputation on FTE.rogue40 has a great reputation on FTE.rogue40 has a great reputation on FTE.
It was even originally Bechtel yellow too!
  #32
mikeo0o0o0's Avatar
mikeo0o0o0 mikeo0o0o0 is offline
mikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud of
Deutz Diesels are great engines. I used to work on them years ago. As I recall, the F5L-912 is around 90 BHP and weighs close to 800 lbs.
  #33
Old 10-28-2013, 03:05 AM
montana_highboy montana_highboy is offline
montana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud of
Is this Deutz chain driven or gear driven?
Timing chain wise....
  #34
Old 10-28-2013, 09:48 AM
mikeo0o0o0's Avatar
Quote:
Originally Posted by montana_highboy View Post
Is this Deutz chain driven or gear gear driven?
Gear drive.
  #35
Old 10-28-2013, 01:20 PM
MBDiagMan's Avatar
MBDiagMan MBDiagMan is offline
MBDiagMan is gaining momentum as a positive member of FTE.
Was this a factory built truck or created in the aftermarket.
When I was in Germany as a young GI, ca. 1969, my girlfriends Dad had a Deutz tractor with an air cooled engine. It was a honey, but I don't know how well it would work in a really hot climate.
I was recently helping on some waterline we were laying for our Veterans memorial. A friend of mine showed up with an ancient Ditch Witch that had a three cylinder Deutz.
I can see where it would have worked quite well in Alaska. That is as well as any diesel can operate in an arctic environment.
  #36
Old 10-28-2013, 01:34 PM
raytasch's Avatar
raytasch raytasch is online now
Old guy with old toys
raytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant future
Very neat truck. Don't worry about the Deutz overheating if it can get air to it. They'll run all day in 100 degree + temps, stationary applications, tractors.
  #37
Old 10-28-2013, 07:04 PM
rogue40's Avatar
I have had my Lincoln ClassicII welder for over twenty years. That three cylinder Deutz has carried me through California Central Valley pipeline jobs at 100+ and even spent one winter in Skagway at the coal dock when the wind was howling down White Pass at about a forty below wind chill.
As long as it has a battery that thing will run and I get about forty hours out of a tank of diesel. They are remarkable machines.
  #38
Old 11-06-2013, 10:12 PM
Boss9F100's Avatar
Boss9F100 Boss9F100 is offline
Boss9F100 has a very good reputation on FTE.Boss9F100 has a very good reputation on FTE.Boss9F100 has a very good reputation on FTE.
Deutz Update
A bit of info on the Duetz 75 Crew
The Deutz conversion was a $8,000.00 option way back in the day.
The 912 Is still being made by Deutz in multiple configurations
Will try to post a few pics of conversion.
Pretty neat how the Deutz is mated to the trans and then a drive shaft runs back into the transfer case a couple feet towards rear.
With a bit of tuning it no longer smokes! Maybe a bit when you rev it.
Ran out of fuel on test drive but just add fuel and it cranks right up! Unlike a late model diesel where you burn the starter up trying to get it going.
Need to upload a few pics..
This truck has the F5L912 Its rated 100HP and 300 something tq
Word is in a truck or van it will give 30mpg when tuned properly.
The rear axle was toast and patched, the 4.10 gears were gone. Stole a gear set out of a '66 F250. Only diff was the spline count on the yoke, used the '66 yoke and a 369 Precision u-joint.. Dana 60 parts are expensive . . Yup a factory Limited Slip 4.10
  #39
Old 11-06-2013, 10:22 PM
Boss9F100's Avatar
Oh yeah, Almost forgot they came with a 300,000 mile warranty!
  #40
Old 11-06-2013, 10:53 PM
earthquake68's Avatar
earthquake68 earthquake68 is offline
earthquake68 has a very good reputation on FTE.earthquake68 has a very good reputation on FTE.earthquake68 has a very good reputation on FTE.
Rich. That second truck looks awfully familiar.
That diesel would be a cool tow rig for the monster truck.
  #41
Old 11-07-2013, 03:04 PM
lurch460's Avatar
lurch460 lurch460 is offline
lurch460 is gaining momentum as a positive member of FTE.lurch460 is gaining momentum as a positive member of FTE.
Have a deutz engine in a roller at work, probably the same engine. Thing runs like a clock, rest of the machine is falling apart but it always starts.
  #42
Old 11-07-2013, 10:18 PM
Mattrm Mattrm is offline
Mattrm is starting off with a positive reputation.
Really cool truck. Please post more pics
  #43
Old 11-07-2013, 11:25 PM
RunninD's Avatar
RunninD RunninD is offline
RunninD is gaining momentum as a positive member of FTE.
I'm curious about your power and economy as well. The Deutz has a better Cool factor for me than a Cummins, and I think I know where there are a couple near me. Also when you get to it, what is the truck using for a tranny?
  #44
Old 11-07-2013, 11:26 PM
Powerstrokepentz6.0's Avatar
Powerstrokepentz6.0 Powerstrokepentz6.0 is offline
Powerstrokepentz6.0 is starting off with a positive reputation.
I'm a fan That's a really nice truck with the deutz diesel wish I could find one. Lol
Liked to see more pics
  #45
Old 11-07-2013, 11:38 PM
Pickupmanx2's Avatar
Pickupmanx2 Pickupmanx2 is offline
Pickupmanx2 is a splendid one to beholdPickupmanx2 is a splendid one to beholdPickupmanx2 is a splendid one to beholdPickupmanx2 is a splendid one to beholdPickupmanx2 is a splendid one to beholdPickupmanx2 is a splendid one to beholdPickupmanx2 is a splendid one to behold
Ok,, that is just flat out AWESOME!!! I had forgotten about the Deutz diesels, and to have one in a Dent!!! A CREW CAB DENT!!! Cool factor of a bozillion!
Couple Q's--cooled seats, fuel mileage, etc on a 13-14... YoGeorge 2007 - 2014 Expedition & Navigator 8 01-05-2016 12:44 AM
'92 300 6-cyl-Changed water pump and I now have gurgling behind the dash? 92 Red F150 1987 - 1996 F150 & Larger F-Series Trucks 2 11-08-2015 01:39 PM
1991 F35 ping/rattle under slight load 1tonMike 1987 - 1996 F150 & Larger F-Series Trucks 47 10-26-2015 06:00 PM
1991 F350 7.5 ping/rattle under slight load 1tonMike 1987 - 1996 F150 & Larger F-Series Trucks 5 10-14-2015 12:43 PM
2007 ranger 4cyl power upgrades? sand1 Ranger & B-Series 1 03-04-2015 11:20 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
