Low idle 1999 5.4 f150 with no codes - Ford Truck Enthusiasts Forums
Old 10-26-2013, 03:07 PM
Shernius Shernius is offline
Shernius is starting off with a positive reputation.
The truck ran fine this morning and this afternoon I had trouble with the truck running at idle.
The idle is at about 450RPM in park. Runs smooth with no miss but if you bring the idle up and then let off quickly it stalls. Can stall while trying to idle at warm up also. Sometimes it will stall at a light but I think it is related to taking my foot off the pedal quickly.
There is no check engine light on and there are no codes.
I have 138K on the engine now. Both air & fuel filter were replaced about a month ago as well as the PCV valve.
Old 10-26-2013, 04:04 PM
Replaced the plugs at about 105K.
Replaced the MAF about two months ago. Had no noticeable conditions but the check engine light came on and I got codes.
Cleaned out the AIC valve around 4 years ago but had different conditions like stumbling while cruising at highway speeds and idle dropping when stopping at the light. The idle with the AIC vale problem always came back up to normal. *Just found my old post from 4 years ago and it seams I did have similar conditions but the truck threw a code back then. Maybe I need to get someone else to read for codes.
Old 10-26-2013, 05:04 PM
projectSHO89 projectSHO89 is online now
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
It's either a vacuum leak or it's a sluggish IAC valve.
Old 10-26-2013, 05:53 PM
I sprayed around with some starting fluid and the idle didn't jump up so It could be the AIC valve.
Old 10-26-2013, 09:30 PM
That trick rarely, if ever, works with modern computer-controlled engines.
Old 10-27-2013, 05:23 PM
Spotty Spotty is offline
Spotty is gaining momentum as a positive member of FTE.
Mine has done that on and off for years. If you have worked on it you know where the IAC valve is. I tap mine with the handle end of a big screwdriver and she idles right up and I'm good sometimes for months. I am so disgusted in the quality of replacement parts these days,that the original sporadic one that is almost 16 years old is probably better then a new one...maybe.
Old 10-27-2013, 07:02 PM
That's what it was alright. I lost a socket and short extension down between the intake runners and into the valley. I can forget about getting those back.
01 7.3 f250 rough idle help! Tyler Labaume 1999 - 2003 7.3L Power Stroke Diesel 8 10-21-2016 03:16 AM
6.0 stalling above idle under load Enduroman 6.0L Power Stroke Diesel 32 08-15-2015 12:35 PM
truck giving me fits(stalling now) Jeramyb 1987 - 1996 F150 & Larger F-Series Trucks 0 08-03-2014 09:57 PM
***Inconsistent Idle*** LARIAT 85 1973 - 1979 F-100 & Larger F-Series Trucks 10 11-05-2011 08:44 AM
Got code reader, where do I start? Anafiel 1978 - 1996 Big Bronco 16 03-12-2011 08:21 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
