NO SPEEDO ! - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
NO SPEEDO !
Old 10-26-2013, 12:52 PM
Smokiesman's Avatar
Smokiesman Smokiesman is offline
Smokiesman has a very good reputation on FTE.Smokiesman has a very good reputation on FTE.Smokiesman has a very good reputation on FTE.Smokiesman has a very good reputation on FTE.
NO SPEEDO !
My friend picked up a really nice 01 F350 at auction the other nite. Most of the cluster seems to work other than the speedo! Also getting the blinkin lite on the OD button which is suppose to be stored trans codes. We took it to our local shop who used the correct scanner but could not pull any codes.So I picked up a new cluster and we installed and still no joy? We are installing a new VSS sensor today. My question is that I read on some other forums that the front ABS sensor are interconnected to the rear VSS and sends a combined signal to the PCM! Does that sound right ? Hate to take to the stealer so if any ideas out there I am all ears and the Cruise Con doesn't work!! Thanks
Smokie
Old 10-26-2013, 01:28 PM
ebbnflow's Avatar
ebbnflow ebbnflow is offline
ebbnflow is gaining momentum as a positive member of FTE.
On my truck, OD light blinked randomly, speedo stopped working, but also my go pedal stopped working. Turned out to be a blown fuse caused by a short in the wire going to the OD button in the shifter. I forget which fuse blew. I replaced shifter and problem is gone.
Old 10-26-2013, 01:32 PM
Smokiesman's Avatar
The guy at the shop said he checked the fuses ! He is pretty good but I think they need to be checked again! Thanks for the tip!
Smokie
Old 10-26-2013, 03:12 PM
Christof13T's Avatar
Christof13T Christof13T is offline
Christof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant future
Had a similar gremlin with motorbug.
No speedo... od light would flash like clockwork as soon as overdrive would normally be dropping in. Turned out to be wet gem/fusebox from leaking roof marker lights.
No luck with hairdryer... it just took a few days and it just started working like normal.
Sealed up my roof markers and have not since had any electrical gremlin shenanigans..
Old 10-26-2013, 07:05 PM
stinson 108-1's Avatar
stinson 108-1 stinson 108-1 is offline
stinson 108-1
stinson 108-1 has a very good reputation on FTE.stinson 108-1 has a very good reputation on FTE.stinson 108-1 has a very good reputation on FTE.
Blinking od light, no cruise and no speedo is classic vss. Get an oem for the better fix if you can. Aftermarket is ok short term. My experience is they seem more trouble free than a cps, but oem is usually the way to go.
Old 10-26-2013, 09:51 PM
caverjoe's Avatar
caverjoe caverjoe is offline
caverjoe has a very good reputation on FTE.caverjoe has a very good reputation on FTE.caverjoe has a very good reputation on FTE.
Mine did the same thing years ago. I took it in and I am guess it is the vss like stinson said sept I dont realy know what that is. Mech said it was a sensor down by the transmission. (? speed sensor maybe)
Old 10-26-2013, 10:43 PM
Smokiesman's Avatar
Joe ! the sensor is in the rear diff! My bud picked up one from Advance! I hope it is not a POS!
Smokie
Old 10-28-2013, 09:18 PM
caverjoe's Avatar
Quote:
Smokie
good to know thank you
Old 10-28-2013, 11:52 PM
Smokiesman's Avatar
Update ! We replaced the sensor in the diff and double checked all the fuses and still no joy! Looks like it might have to go in the shop!!!
Smokie
Old 10-29-2013, 06:03 AM
scottnchrissy's Avatar
scottnchrissy scottnchrissy is offline
scottnchrissy is starting off with a positive reputation.
I don't have an auto trans but I have read about the OD wire chaffing and causing problems. Look up the failure prevention thread.
Old 10-29-2013, 10:16 AM
caverjoe's Avatar
Quote:
R U talking about the wires at the steering column Scott?
Old 10-29-2013, 10:23 AM
Quote:
Those are the ones.
Old 10-29-2013, 12:19 PM
BillyBob69's Avatar
BillyBob69 BillyBob69 is offline
BillyBob69 is a name known to allBillyBob69 is a name known to allBillyBob69 is a name known to allBillyBob69 is a name known to allBillyBob69 is a name known to allBillyBob69 is a name known to all
Ditto. I had the same issue on my E99 and it was a chaffed wired. Just added about 2 inches of length for addition play and less pulling rubbing when tilting the steering wheel and all is good for about 7 yrs now.
Old 11-04-2013, 06:56 PM
Smokiesman's Avatar
Update: sort of! My buddy took it to the dealer and and they can get no ABS signal! Said he needs a new ABS to the tune of hold onto yer butt $1800.00 ! So today we made a trip to the boneyard in Asheville and got one for $100. go figure. So now they are going to install and we wait on the results!! This will be interesting? Will keep ya posted!!
Smokie
Old 11-04-2013, 10:25 PM
Bonanza35 Bonanza35 is offline
Bonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to behold
Got to see what happens here.
E40D transmission/Ignition problem...Any advice would help FoMoCoFan52 1987 - 1996 F150 & Larger F-Series Trucks 13 04-03-2015 06:16 PM
Speedo/VSS/P0528/P0500 HELP Devilmanak 1999 to 2016 Super Duty 10 04-14-2014 10:56 PM
7.3 turb idi no speedo mroth2008 1987 - 1996 F150 & Larger F-Series Trucks 2 12-28-2013 08:18 PM
96 F350 7.3 VSS Issues: like chasing a rainbow? Quik 1987 - 1996 F150 & Larger F-Series Trucks 1 09-26-2013 01:25 PM
PO500 vss confusion wvcat 1997 - 2003 F150 2 11-19-2011 06:47 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
