Transmission Cooler Lines
I thought I would share what I've done so far.
The threads are a m18-1.5, It's rather a fine thread for that size, but it does exist. I purchased a tap and a 1 1/5 inch long bolt. I used the tap "very carefully" to clean up the threads. I then put teflon tape on the connectors to thread in to cooler. I screwed the bolt in to one side to use it as leverage to get the other side up close to the opening in the plastic. I then, again, "very carefully", screwed the male portion in to the cooler throuogh the plastic bottom of the radiator. I then used a 1" socket on a 1/2" drive rachet to tighten up the male threads.
Once the first side was done, I then repeated the process on the other side with the teflon tape again.
I'm about the put the radiator back in and check everything. I'll update this thread to let everyone know if I was successful or not.
If I am, the total cash outlay will be about $55. If not, I'm out the cost of a new radiator.
Well Casey struck out at bat!!!
Everything was going well. I had the radiator back in and tested the tranny line connections. Both connections were leaking, so I got under the radiator with a crescent wrench and started torqueing. The driver's side connection torqued down just fine, but the passenger side seems to have stripped, and rather easily at that. This is surprising as the passenger side had more good threads to start with.
I'm now looking at BPD for an all-aluminum radiator.
Heck, it was worth a try and I learned something to boot!!!!!
Wanted to update the forum with my progress.
I ordered the BPD radiator and it came in just fine. The radiator had the threaded connectors for the tranny lines, but included the quick disconnect nuts as well, so I swapped them out. BPD also included a spare plastic drain valve, just in case the one on the radiator gets cracked during shipping.
Dropped the radiator in, connected the tranny lines and all the hoses. Took about 30 minutes. (I was taking my time to make sure I didn't buggered anything else.)
The truck;s been running fine for about a week now. I'm not losing any coolant (which was the original issue).
All is right with the world!
Again, thanks for all the help from this forum. You guys (and girls) are a godsend...
HAPPY THANKSGIVING!!!!!!!
happy thanksgiving! i remember having some issues but mine was the external tranny filter housing where i broke off tat stupid nut. i ended up just getting the entire set for the external tranny filter housing. it comes pre-installed with a new filter as well….. and then i learned tat ford also has ANOTHER external tranny filter housing setup, where this "other" setup utilizes the magnefine filter, and it's way they call their "inline" setup. this "inline" setup only comes on rebuilt ford trannys for our trucks.
bellinoracing
2004 - 2008 F150
52
09-10-2019 11:26 PM
302 richie
04-20-2019 07:57 PM
