How much should it cost to have fuel pump replaced? - Ford Truck Enthusiasts Forums
Old 10-25-2013, 12:03 PM
mrsvegan's Avatar
mrsvegan mrsvegan is offline
mrsvegan is starting off with a positive reputation.
Hi guys,
Can someone please ballpark me on what it should cost to have the fuel pump replaced on a 2001 Excursion 7.3?
Old 10-25-2013, 12:28 PM
timmyboy76's Avatar
timmyboy76 timmyboy76 is online now
timmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to behold
not sure, but remember reading that the fuel pump located in the tank. Our trucks, the pumps' located on the frame. Either way, if you got the time, do it yourself.
Old 10-25-2013, 01:04 PM
excavator's Avatar
excavator excavator is offline
excavator is gaining momentum as a positive member of FTE.
are you sure you need fuel pump? I just had a low fuel psi reading on a gauge hooked up to my 99 F350. It was reading 25 psi at idle and lower raising throttle. I placed order for new FPR rebuild kit and after install I now have 65 psi at idle. I got kit from Diesel O-Rings .com
Old 10-25-2013, 04:39 PM
Robert6401's Avatar
Robert6401 Robert6401 is offline
Robert6401 is a name known to allRobert6401 is a name known to allRobert6401 is a name known to allRobert6401 is a name known to allRobert6401 is a name known to allRobert6401 is a name known to all
mrsvegan,
Let us know what makes you think you need a new fuel pump. They do fail, but not all that often. I'd be willing to bet if you're having an issue it's something else and the mechanic is trying to throw parts at the problem. Let us help you. Where in GA are you? I'm in SC and can possibly help if you're not too far, and there are other forum members in GA. Don't pay for a new pump until we get you in the right direction.
Old 10-25-2013, 04:41 PM
Robert6401's Avatar
I should've added, however, that it should take less than an hour to replace the fuel pump . So cost of pump, plus one hour of labor should be total cost to pay someone else to do it. Still doubtful that the pump is the issue, though.
Old 10-25-2013, 05:51 PM
Nicmike's Avatar
Nicmike Nicmike is offline
Proud Sheepdog
Nicmike has a spectacular reputation.Nicmike has a spectacular reputation.Nicmike has a spectacular reputation.Nicmike has a spectacular reputation.Nicmike has a spectacular reputation.Nicmike has a spectacular reputation.Nicmike has a spectacular reputation.Nicmike has a spectacular reputation.Nicmike has a spectacular reputation.Nicmike has a spectacular reputation.Nicmike has a spectacular reputation.
Pumps run about $160 for OEM (Bosch). Labor can be $60-100 for an hour. I just replaced mine last month. Very easy job.
Old 10-25-2013, 08:22 PM
mrsvegan's Avatar
Hi Guys, Earlier in the week I posted this thread:
http://www.ford-trucks.com/forums/12...-cold-day.html
Our local diesel shop (kinda weird people) said they could not put it on the computer until Monday. I changed the fuel filter today and it was falling apart (I know I know) I thought that my Excursion had a light that came on like our 250 does that told when the fuel filter needed to be changed. Apparently that is not the case. Anyway, changed the fuel filter thought that would fix the problem. My husband then test drove it to see if it was fix and it barely got him home it was so bad. He said he feels it is some kind of fuel delivery issue, possibly the fuel pump. Called around today and was not super happy with any of our option here but will go talk to some people face to face Monday I guess. I am hoping like heck we didn't end up trashing the injectors with the cruddy fuel filter.
Old 10-25-2013, 08:34 PM
mrsvegan's Avatar
Quote:
Where did you buy it from?
Old 10-25-2013, 08:49 PM
Stewart_H's Avatar
Stewart_H Stewart_H is online now
The Nekkid Super Mod
Stewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputation
Quote:
What year is your F250, and what kind of engine?
Stewart
Old 10-25-2013, 08:54 PM
t.scottNDU's Avatar
t.scottNDU t.scottNDU is offline
t.scottNDU has a good reputation on FTE.t.scottNDU has a good reputation on FTE.t.scottNDU has a good reputation on FTE.
I replaced mine last month as well. I purchased it from dieselorings.com.
It's a very easy job, the only "special" tool would be a 5/16 fuel line disconnect tool, everything else uses common wrenches, sockets, etc.
You will need to reuse the fitting on the push side of the pump, as well as the insulating cover and mounting bolts. New one should come with new nuts and washers for the electrical connection.
How many miles on the Ex? I'm with the other guys, it's too big of a coincidence that this is happening directly after the fuel filter debacle you described.
Just out of curiosity, do you know how many miles you had on the old filter? They should be changed every 10k. I change mine every 5k.
Old 10-25-2013, 09:28 PM
lartross's Avatar
lartross lartross is offline
lartross is gaining momentum as a positive member of FTE.
There's a good chance it's a clogged screen in the in tank pick-up. There a hutch mod would be a good path to take. 'Course, someone has to do the wrenchin'....
Old 10-25-2013, 10:13 PM
Nicmike's Avatar
Proud Sheepdog
Dieselorings.com of course! $145...However, he is out of stock on them. I also own a 2001 X, and the pickup foot in the tank had fallen apart. I did the hutch mod on it to remedy that and future problems. You have guys in your area that are willing to help you out.
Old 10-26-2013, 07:16 AM
tdpower's Avatar
tdpower tdpower is offline
tdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to behold
If they get a pump from the dealer they list for $350 or more plus labor. Could also be the screens in the tank like lartross suggested.
Old 10-26-2013, 08:04 AM
mrsvegan's Avatar
Quote:
Stewart
It's a 1995' 7.3
Old 10-26-2013, 08:06 AM
mrsvegan's Avatar
Very ashamed to say that poor fuel filter was on there for about 150,000 Miles
My EX has 217,000 on it.
Fuel Pumps are dying. Holmesuser01 1987 - 1996 F150 & Larger F-Series Trucks 10 05-15-2015 07:50 PM
Cost to Replace Y Pipe on v.10 Excursion Mbp002 Excursion - King of SUVs 5 12-03-2012 10:05 AM
Ford Reaquired Vehicle - RAV frayfl 1999 to 2016 Super Duty 21 02-16-2011 09:15 PM
Ecoboost parts cost solaratomic 2009 - 2014 F150 18 12-06-2010 12:09 PM
Fuel Filter causing fuel pump failure? jquise2423 1999 to 2016 Super Duty 15 06-01-2010 01:24 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
