Glow plug relay? Controller?
on a 99 7.3 psd is there a Glow plug relay and a Glow plug controller? I keep getting both options. One looks like a solenoid and the other looks like a heatsink with two plugs on the bottom.
I have found the one that looks like a solenoid but not the other. My buddy has one that looks like the other on his 6.0 (poor *******).
Thanks in advance!
Dale
Thanks in advance!
Dale
California trucks had the GPCM and Federal trucks had the relay. You will have one or the other. This is assuming you have a L99 model truck.
If it is an E99 model truck, you will have a relay regardless of if it is California or Federal. The California model E99 trucks had a bridge that straps over the relay to monitor both banks of glow plugs. The Federal model E99 will just have the standard relay.
Would it have both if it were cali? I found the one in my truck on top of the valve cover that looks like the starter solenoid.
The one I got from Rockauto was motorcraft. Is that considered aftermarket? Here is the one from Riff Raff if that helps...
http://www.riffraffdiesel.com/mm5/me..._Code=F731-OEM
Are you including Stancor in that statement?
No, OEM is OEM. It doesn't matter where you get it. It could be from ebay or anywhere.
Anything that isn't OEM is considered aftermarket.
Stewart
Stewart
bobwhyte2002
05-06-2012 10:30 PM
Ravenous Weasel
01-17-2012 08:30 AM
Israelx7
08-07-2011 11:50 PM
