2008 Navigator--Interior light problems - Ford Truck Enthusiasts Forums
2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Old 10-25-2013, 11:36 AM
ASTROENG2011 ASTROENG2011 is offline
ASTROENG2011 is starting off with a positive reputation.
OK. I need some help. I have no interior lights coming on when you open the doors. Running boards extend when door opens but no interior lights. I checked fuse- still good. Lights work manually--come on when you push them. I checked the dimmer switch to see if it was in off position. Nope set mid range of control. So, where do I go from here. I seems there is another timer control or convenience control that tells the interior lights to come on and go off after a set time depending on door position(open or closed). I cannot find any such module. Anyone have any ideas where I should start to look?
Old 10-25-2013, 12:45 PM
gpfarrell gpfarrell is offline
gpfarrell is starting off with a positive reputation.
I don't know the answer for a Navigator, but if my Mercury Marauder had this problem I'd suspect the Lighting Control Module (LCM). I'd try to bark up that tree if you can find it.
How to defeat interior lights ?? Jose A. Aerostar 0 10-04-2016 09:01 AM
No Interior Lights jhcorley Excursion - King of SUVs 22 06-05-2016 07:37 AM
03 Navigator - interior lights won't turn off??? superv10 1997-2006 Expedition & Navigator 5 04-04-2016 11:29 AM
interior lights do not turn on when doors open Kongerup Excursion - King of SUVs 8 01-13-2015 07:51 AM
Footwell lamps? cbrown9064 2004 - 2008 F150 0 11-02-2013 07:29 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
