Front axle does not drive wheels
not sure about the "manual shift", but most of the 4 x 4 have a vacuum cylinder mounted to the side of the pumpkin and it engages a pin in the pumpkin to tie the driveshaft to the two axle half shafts. Look at the front axle and see if you have two vacuum hoses running to a small air cylinder.
---or maybe you have a cable that pulls- pushes the pin ??
gartlesby
09-20-2017 09:30 PM
smashclash
09-07-2010 08:22 AM
