63 F100 4x4 - Wheels and Tires Help - Ford Truck Enthusiasts Forums
Old 10-24-2013, 07:16 PM
KsCop's Avatar
KsCop KsCop is offline
KsCop is gaining momentum as a positive member of FTE.KsCop is gaining momentum as a positive member of FTE.
Since my project is getting closer to completion, and my tires are 100% shot;
I'm looking for wheel and tire options. Since it's a 4x4, I'd like something that would suit it and the current steels wheels just don't seem to do so
I don't have a lift on the truck, but it seems to sit pretty high on it's own..
Any decent wheel and tire suggestions that won't break the bank?
Old 10-24-2013, 08:16 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
2WD/4WD same 5 lug, 5.50" bolt circle wheels: 1953/79 F100 - 1966/96 Bronco - 1969/72 E200 - 1975/96 F150 - 1975/2013 E100/150 / Some 1980/83 F100's have 5 lug 5.50" some have 5 lug 4.50" bolt circles.
Some 1965/66's, all 1967 and later are "outie" wheels. Hubcap snaps over tabs located on the outside of the wheels center section.
Some 1965/66's, all 1953/64's came with "innie" wheels. Hubcap snaps over tabs located on the inside of the wheels center section.
1977: First year for Styled Steel & Aluminum wheels for F100/150's, Bronco's got 'em in 1978. Same/similar wheels used thru 1996.
The hubcaps (Ford called 'em ornaments) are either black or chromed plastic, attach to the wheels with 3 black or chrome screws using expanding anchors, holes located within the bolt circle.
Old 10-24-2013, 08:46 PM
KsCop's Avatar
Thanks for the information, I guess I need to clarify a little.
I'm trying to decide on wheel size and tire size and am looking for ideas that will work without a lift
I am considering 16x10 (5 on 5.5) with 35x12.5x16.5 tires; I'm just not sure if they will run OK on my truck (stock height)
I think the stock wheels are 15. Not sure what tires are on it now, but they look pretty small in relation to the truck
I saw a picture (red 63 4x4, Eric) that has the look I'm after but don't know what wheels and tires he has on it
Old 10-24-2013, 09:36 PM
Your truck has the 1957/60 'wrong' Styleside bed that has large rear wheel openings.
So you shouldn't have any clearance problems with wider than the original 5 lug 15" or 16" wheels that were 5.5" wide (FoMoCo measures across from inside flanges).
Old 10-24-2013, 11:23 PM
crazed87bronco's Avatar
crazed87bronco crazed87bronco is offline
crazed87bronco is gaining momentum as a positive member of FTE.
Not sure if 35's will fit or not with stock height I know 33's will I ran 33x12.5x15 rims and tires on my stock height 64 f100 4x4 with the right back spacing 35's might clear sure someone else will chime in and be able to tell more on running 35's here's my truck just to give an idea on tires and rims
Old 10-25-2013, 12:50 AM
KsCop's Avatar
I think 33's might do the job for me
Old 10-25-2013, 04:39 AM
Shadowrider123 Shadowrider123 is offline
Shadowrider123 is starting off with a positive reputation.
Do you have power steering?
I like oem white steel wheels myself.
I think 90s Econolines ran a 16x7.5 steel wheel with slots around the outside.
Old 10-25-2013, 05:22 AM
KsCop's Avatar
No power steering
No power brakes
No power windows
Just raw 292 y block power...
T98a 4 speed
Dana 24 xfer case
Ford 9" rear
Dana 44 front
Old 10-25-2013, 08:24 AM
tinman52's Avatar
tinman52 tinman52 is online now
Welder User
tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.
The bigger tires (wider) will make it a lot tougher to steer at low speeds. I have 245/16's on mine.......they are not too bad.
Old 10-25-2013, 11:18 AM
kjvforme's Avatar
kjvforme kjvforme is offline
kjvforme is a name known to allkjvforme is a name known to allkjvforme is a name known to allkjvforme is a name known to allkjvforme is a name known to allkjvforme is a name known to all
I'm running 31x10.5-15's on my 1962 and they work great. Just remember the larger the tire the more power it takes to move them. you'll have to swap diffs to get back the power. The other problem is speedo calibration will be off.
Old 10-25-2013, 12:13 PM
oaklandford oaklandford is offline
oaklandford is starting off with a positive reputation.
Oversize tires and wheels will not only make steering harder, it will wear out the front end sooner. A tall narrow combo would work best on a 4x4 , 215-85-16 would be my choice.
Old 10-25-2013, 12:45 PM
schoo's Avatar
schoo schoo is online now
schoo has a great reputation on FTE.schoo has a great reputation on FTE.schoo has a great reputation on FTE.schoo has a great reputation on FTE.schoo has a great reputation on FTE.
i'm using 9.50x16.5 and its a little hard to steer going to 225 x16 85 on more modern 16" wheels
Old 10-25-2013, 01:32 PM
I think you would have to have the hub opening made bigger to fit a 4x4, but I like these.
05 Dodge Ram 17" wheels and tires
Old 11-06-2013, 12:01 PM
KsCop's Avatar
After some consideration regarding cost, steering and looking at what is currently on the truck, I went with 265/75R-16 tires. The wheels on the truck are 16" currently and after getting the clip back on I think that tire will be fine.
My next question is wheels. I'm thinking about the Black Rock Lobo 950 series. They have a 16x8 5 on 5.5 wheel, 0 offset, 4" backspacing. My big question is if that would work on the 4x4
Thoughts?
Old 11-06-2013, 03:43 PM
How can an 8.5in wide wheel have both zero offset and a 4in backspace?
Zero offset means the mounting surface is exactly in the middle of the wheel.
4in backspace means the mounting surface is 4in from the rear of the wheel.
There is a 1/2in difference.
Factory wheel and tire size on 4x4 Amphihauler 1961 - 1966 F-100 & Larger F-Series Trucks 1 07-21-2016 11:20 PM
tire size question BIGRED 011 1999 to 2016 Super Duty 3 07-16-2016 08:42 AM
What size and offset wheels for 33" tires? the_auto_tech 2009 - 2014 F150 2 03-09-2016 06:47 PM
A complex tire and wheel question DieselVol 1999 to 2016 Super Duty 3 03-02-2015 11:57 AM
Clearance for 40" tires and offset JR250R Offroad & 4x4 4 05-11-2014 06:17 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
