Front Coils on 13 Superduty - Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8
Old 10-24-2013, 06:05 PM
JAE88 JAE88 is offline
JAE88 is starting off with a positive reputation.
Would anyone happen to know if the front coils are the same on the gasser as the diesel, or are they ones on the gasser a little softer?
Old 10-24-2013, 08:08 PM
Powelligator's Avatar
Powelligator Powelligator is offline
Powelligator is starting off with a positive reputation.
Gas or diesel makes no difference, front springs are determined by the payload package. Here is a list of front springs, their capacities and the part numbers. Part numbers can be determined by a tag on the spring itself.
F-Super Duty Monobeam Coil Spring Rates (F250/350 4x4)
Front GAWR Rating Current Vehicle Spring Coil P/N 5C34-5310-xxx
4000lb. 5C34-5310-AHC
4400lb. 5C34-5310-AGC
4800lb. 5C34-5310-AFC
5200lb. 5C34-5310-AEC
5600lb. 5C34-5310-ADC
6000lb. 5C34-5310-ACC
Joe
Old 10-24-2013, 09:26 PM
Ok, thanks
Old 10-25-2013, 11:31 AM
2000silverbullet's Avatar
2000silverbullet 2000silverbullet is offline
2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold
Anyone know the weight difference between the 6.2 and 6.7? I would bet that would make a pretty significant difference in ride with the same front springs..
Old 10-25-2013, 11:59 PM
BossGasser BossGasser is offline
BossGasser is gaining momentum as a positive member of FTE.BossGasser is gaining momentum as a positive member of FTE.
About 700 lbs on curb weight.
Hard to know without a weigh in.
Old 10-26-2013, 08:27 AM
Quote:
That's why i thought maybe the springs on the 6.2 would be a little softer. I will try to check my spring tag today and see which ones i have.
Old 10-26-2013, 10:53 AM
Quote:
Yep, I figured it'd be good to have the information out here in the forum.
I have zero complaints about the way my truck rides. The shocks and steering stabilizer upgrade made a huge improvement.
Old 10-26-2013, 09:31 PM
My front springs are the 4800lb. 5C34-5310-AFC
Old 10-27-2013, 06:51 AM
T diesel T diesel is offline
T diesel has a good reputation on FTE.T diesel has a good reputation on FTE.
My 2013 f 250 camper package with snowplow prep
is front 5600 rear 6200.
1994 F250 mutant build rterril02 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 4 06-05-2016 05:51 PM
Anyone thought about a GASSER truck build ? ken selvy 1973 - 1979 F-100 & Larger F-Series Trucks 2 11-13-2015 11:10 PM
F-250 coil springs stiffness difference Grosjo 1999 to 2016 Super Duty 5 08-27-2014 03:01 PM
Removing front clip for engine swap jimlj 1973 - 1979 F-100 & Larger F-Series Trucks 9 09-26-2012 07:59 PM
Anybody got a front sway bar? Sycostang67 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 7 09-09-2010 09:05 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
