C1726 2007 Expedition - Ford Truck Enthusiasts Forums
2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Old 10-24-2013, 04:00 PM
Lowe's Avatar
Lowe Lowe is offline
Lowe is starting off with a positive reputation.
I am getting the code C1726 (Air Suspension Rear Pneumatic Failure)-- I have done various trouble shooting. Neither of the Two Leveling devices are bad. I have removed the Airlines from each bag and with a bit of running back and forth to turn the key on and off and close the door I have inflated both with external air and neither seem to have leaks. I have uncoupled the leveling arms and confirmed the control module does recognize vehicle height and it demand the pump at various positions. I blow a little pressure (10-20psi) in to the vehicle air line and it appears to hold but when I apply suction it doesn't. Anyone have any experience with typical failures on these systems? I suspect the compressor is bad and unable to build pressure as I can hold my finger over the hose when the compressor is running. Any feedback is appreciated!!
Lowe
Old 10-25-2013, 02:12 PM
Lowe's Avatar
Update:
after monkeying around with it most of yesterday I have finally determined its the compressor. I manually inflated both bags and disconnected the solenoids at each air-bag just to be sure I didn't have a bag leaking. As of now both bags are completely inflated with no change in vehicle level. New compressor to arrive Wednesday Oct 30th and will be installed shortly after.
Lowe
07 Navigator L air suspension issue - help needed BlackTruckPL 1997-2006 Expedition & Navigator 6 04-25-2016 02:21 PM
07 Navigator L air suspension issue - help needed BlackTruckPL 2007 - 2014 Expedition & Navigator 0 04-23-2016 03:19 PM
F350 Super Duty Turbo Diesel Part Recognition? bigjoe8 1999 to 2016 Super Duty 2 06-07-2015 11:21 PM
A/C Problems: Compressor Short Cycling? AggieOutlaw Excursion - King of SUVs 9 05-19-2015 02:26 PM
Voltage at compressor - no clutch engagement? tobyw Cooling, Heating, Ventilation & A/C 20 06-04-2007 12:08 AM
Tags
air suspension, c1726, rear air suspension, rear pneumatic failure
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
