New truck/old fuel
New truck/old fuel
Hello, I just bought a 2008 F350 with the 6.4. It came with a transfer tank in the back that has approx. 52 gallons in it. I took about a half gallon as a sample, and it appears ok, but it smells "weak" I guess. The truck was bought from a dealer that got it from an auction, so I have no idea how old it is. Is there anyway to safely run it with dieselkleen? I just put it up on craigslist, but wondering if I can use it.
PS. How can I add a picture?
If you plan on doing any long distance towing you might want to rethink getting rid of that tank. With the stock tank and pulling any significant weight when you get on the interstate you can see almost as far as you can go before refueling. I added a 60 gallon titan in place of OE and that helped some but now I have installed a 100 gallon in the bed with gravity feed in to the titan. Tried it out a few days ago and works slick as owl s&$@. Now if I plan it right I should be able to avoid buying B20 in the corn states or at least fuel up at a lowest possible price.
Titan Tanks, get 67gal in place of the factory 38gal, loose no bed space, just some ground clearance.
The price is excessive for what it is, a rotomolded tank. I suspect they are trying to recoup the tooling costs too quickly. If they cut the price in half I expect they would still have a profit margin and they would in all probability sell 5X as many units.
I researched a good bit and Titan is competitive with the other vendors. i had a 50 gallon replacement on my last truck and it was around 800 bucks as I recall. That one was steel. I think I like the titan better. The in-bed 100 gallon I got off craigs list for 200 bucks. Had to buy a fuel cap and roll over valve for it. There are always several on the ATL craigs, just had to wait for one that had no mice living in it.
