Bed Removal
Bed Removal
Hello Everyone,
I've tried searching the site but can't find what I'm looking for. Can someone tell me what bolts I need to remove to remove the bed from my 52F1? I've removed the rear fenders to make the bed lighter but only want to remove the bolts I need to, to enable freeing the bed from the frame. Also any idea how heavy the bed is?
Thanks for the help.
If you still have the bed wood attached you can try to unbolt the 2 rear crossmembers from both sides of the frame from underneath. There is also 2 spots in the front by the cab that are bolted to the frame. And I believe there is also a angle piece right under the tailgate on each side that will need to be unbolted. Weight wise I would guess around 250-300 but it will be awkward to lift without help.
Narwhal
35
06-26-2020 07:34 PM
JoeSwing78
02-28-2006 03:34 PM
wilson3821
07-13-2003 03:02 PM
Hit Man X
13
06-06-2003 10:34 PM
