Help locate block heater plug on 1997 E350 - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 10-24-2013, 11:30 AM
cwhjcs cwhjcs is offline
cwhjcs is starting off with a positive reputation.
I can not seam to find the plug for the block heater on my 1997 e350 7.3l. I see the wire goes into a harness from the heater itself but where does it go from there? I do not see it up front
Old 10-24-2013, 12:43 PM
ReBilld's Avatar
ReBilld ReBilld is offline
ReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to behold
The cord comes off of the block heater right above the oil filterand runs down the top of the driver side frame rail. It doesn't go into a harness that I know of. The end with the plug on it should go through the core support somewhere between the radiator and driver side headlight.
Old 10-24-2013, 04:28 PM
OldWoodsDiesel's Avatar
OldWoodsDiesel OldWoodsDiesel is offline
OldWoodsDiesel is gaining momentum as a positive member of FTE.
what you're probably seeing as a harness is just a hard sleeve that the cord (and only the block heater cord, and nothing else) runs through along the top of the frame rail. its held in place with a few of those Christmas tree push pins. pull that sucker straight up and it'll come loose. then you can yank the rest of the cord out from wherever its hiding and re-route it to your preference.
the cord on my new truck was coiled up by the PO up near the hood latch and wire-tied. ...which should have been an obvious sign that it doesn't work! time to test to heater itself...
Old 10-25-2013, 12:49 PM
blageurt's Avatar
blageurt blageurt is offline
blageurt is gaining momentum as a positive member of FTE.
On my Van the PO decided to run it up to the top beside the Heater Box and have it come out between the Hood and the grill...When I replaced it (Twice now) , I ran it along the frame and across the bottom of the radiator and down below the bumper....
Old 04-06-2014, 06:53 PM
wantahertzdonut's Avatar
wantahertzdonut wantahertzdonut is offline
wantahertzdonut is starting off with a positive reputation.
I have a 97 F350 and can't find the plug either. Is it possible my truck doesn't have the heater in the first place?
Help. Block heater on my 1997 7.3 Ria Silvers 1994.5 - 1997 7.3L Power Stroke Diesel 5 01-22-2016 11:57 PM
Huge Coolant Leak. Heater Core I Think leardvr 1968-2013 Full Size Vans 4 04-17-2015 11:16 PM
Engine block heater replacement Bigal700 1994.5 - 1997 7.3L Power Stroke Diesel 6 03-05-2014 03:51 PM
ENgine Block heater combined battery charger? awils961 1987 - 1996 F150 & Larger F-Series Trucks 10 01-12-2011 04:50 PM
block heater location mongo12 1994.5 - 1997 7.3L Power Stroke Diesel 13 12-14-2009 07:31 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
