Tow/Haul mode
Tow/Haul mode
I'm a long time reader of this forum, first time poster. I live in S.FL and I tow a 32ft boat about 3 miles. My question is when should you use the tow/haul button? Is there a minimum weight (rule of thumb to follow)? I do use it when towing boat, but what about my 4000lb (empty)cargo trailer when towing down interstate in the mountains of NC? I do have a H&S mini max, that has a tow mode setting since update. DPF delete, full egr delete, ect.... What would be proper way(gear-drive,3,2,1) to drive this in the mountains of NC? Sorry for my ramble here, just a florida boy used to flat land. Thanks in advance for any advice you guys can give me.
The T/H mode modifies the upshift points and increases pressure to the clutches for better shifting under load. It also keeps the Torque Converter locked up and will downshift the transmission 1) when the computer detects acceleration without pedal imput, and b) when you tap/apply the brakes while decelerating. This T/H option is very helpful when descending steep grades with a heavy load.
There is no 'exhaust brake' on these Fords--what you might think is it, is the trans downshifting and the TC staying locked up.
To confirm this with your H&S----drive normally without the T/H on, you should see the "TC Unlocked" message as the truck begins to coast and slow down. Then do the same in T/H mode and watch the same message as the truck slows down. The message will say "TC Locked" and you will feel the trans downshift. Those downshifts are not felt when not in T/H and the rpms will drop to near idle.
But to answer your question--use it or not, it becomes more useful for heavy loads and steep grades. Your truck will handle the boat and 4k cargo trailer just fine.
Joe
Joe
<style> <!-- /* Font Definitions */ @font-face {font-family:Cambria; panose-1:2 4 5 3 5 4 6 3 2 4; mso-font-charset:0; mso-generic-font-family:auto; mso-font-pitch:variable; mso-font-signature:3 0 0 0 1 0;} /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:""; margin:0in; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-ascii-font-family:Cambria; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:Cambria; mso-fareast-theme-font:minor-latin; mso-hansi-font-family:Cambria; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;} @page Section1 {size:8.5in 11.0in; margin:1.0in 1.25in 1.0in 1.25in; mso-header-margin:.5in; mso-footer-margin:.5in; mso-paper-source:0;} div.Section1 {page:Section1;} --> </style> Since you have a tuner my best advice would be to monitor the truck vitals, water temp, oil temp, Exhaust temp, and trans temp and figure out your tow speed from there. (My personal temp limits towing a heavy load: oil temp 228-232, coolant temp 228-230, trans temp 210-215, exhaust temp pre turbo 1200-1300 sustained load but if oil temps and water temps are over the 225 range I consider 1175-1200 to be my max egt. These are just my personal preferences and for example reference only) ON heavy grades tow at a speed that the truck can maintain these reasonable. My truck is tuned and has plenty of power to pull anything id like. I also have the ability to burn the engine and trans if I ever pushed it to hard. Hers an example one of the areas I haul equipment I have to pull an 18-mile long 7-8 percent grade with a GCVW of about 28-30K. I know the grade pretty well so about when I get into the pull I just set the cruse at about 35-40mph because I know at that speed my truck can handle it no problem, yeah it may take me a bit longer but it is not worth any risk to me to top the hill 5-10 mins faster pushing the truck.
As Sanddemon said, just keep an eye on the temps on the H&S...I run EGT on top, then oil, coolant and trans at bottom. The EGT will track higher as you load the engine on grades--you can either back out of it or downshift to lower. The other 3 will also climb as you work the engine more, but they should all stay below temps that might cause a problem.
Joe
Joe
The mini max will not override the tow/haul mode, although the mini max does somewhat adjust the shifting of the trans it will not operate the transmission like the tow/haul button dose.
My owners manual says:
Do not use the Tow/Haul feature when driving in icy or slippery
conditions as the increased engine braking can cause the rear
wheels to slide and the vehicle to swing around with the possible loss
of vehicle control.
of vehicle control.
