FABRICATION!! We want to see what you've built. - Ford Truck Enthusiasts Forums
Old 10-23-2013, 08:22 PM
Drewski 2's Avatar
Drewski 2 Drewski 2 is online now
Drewski 2 has much to be proud ofDrewski 2 has much to be proud ofDrewski 2 has much to be proud ofDrewski 2 has much to be proud ofDrewski 2 has much to be proud ofDrewski 2 has much to be proud ofDrewski 2 has much to be proud ofDrewski 2 has much to be proud of
The recent thread asking if you kit or fabricate brought to mind a thread that I started over a year ago regarding fabricated or modified parts. I find it really time consuming trying to search for custom work, wading through galleries or using the search feature. I'd like to propose a running thread of your fabrication projects whether made totally from scratch or a modified part.
I belong to several forums where there are threads that have run for quite a long time regarding things like home brewed tools, storage ideas, welding projects, etc..... They are quite interesting to read and even if the way they're presented doesn't work for you, it may give you food for thought on how you might use it. I'm constantly going back to those threads to see what has been added
This may be duplicated information from your build thread and may require a little more effort to post here, but it will be located in one place to see work that others have done and may be what you're looking for.
Old 10-23-2013, 08:27 PM
h2omelon's Avatar
h2omelon h2omelon is offline
h2omelon is gaining momentum as a positive member of FTE.h2omelon is gaining momentum as a positive member of FTE.
Old 10-23-2013, 08:48 PM
oldmanrvr5's Avatar
oldmanrvr5 oldmanrvr5 is offline
oldmanrvr5 is gaining momentum as a positive member of FTE.oldmanrvr5 is gaining momentum as a positive member of FTE.
1956 ford truck frame with a camaro subframe, air bag system installed and many other mods.
Old 10-23-2013, 08:49 PM
Drewski 2's Avatar
53-55 Instrument panel
I'm currently working on my butchered instrument panel. When I got my truck it had the original instrument panel cut up with a several different kinds of gauges mounted in an aluminum panel that was covered in fake wood grain.
I performed a little more surgery on the panel and opened it up where I could mount a real wood panel. I also sanded the rust and paint off the ring that surrounds the instrumets and buffed the ring. I plan to shoot this with adhesion promoter and clear coat. Lot cheaper than chrome and looks better than the paint and rust.
My wife ordered some new Autometer gauges and I searched through my scrap pile of wood in search of just the right piece.
I cut out 3 different panels.....one each in cherry, walnut, and red oak.
The cherry got my wife's vote and it does have some interesting patterns. I cut all the holes for gauges, signal lights and high beam. I'm currently working on the finish.
Updated 10-29-13
Several coats of clear automotive finish.
Install gauges.
Old 10-23-2013, 09:15 PM
Doods54's Avatar
Doods54 Doods54 is offline
Doods54 is starting off with a positive reputation.
<a href="http://s125.photobucket.com/user/calorchard/media/Mikes%20Jeep/photo4_zpse27072f6.jpg.html" target="_blank"><img src="http://i125.photobucket.com/albums/p74/calorchard/Mikes%20Jeep/photo4_zpse27072f6.jpg" border="0" alt=" photo photo4_zpse27072f6.jpg"/></a>
Old 10-23-2013, 09:35 PM
Drewski 2's Avatar
Quote:
Originally Posted by Doods54 View Post
Might want to tell us what you've got going on here.
Old 10-23-2013, 09:57 PM
Rocketman55's Avatar
Rocketman55 Rocketman55 is offline
Rocketman55 is starting off with a positive reputation.
Drew, your post is very timely and I like your setup. I've been working toward something similar but using other materials beside wood. As I'm using redwood for my flatbed I kind of like the idea of having them match.
Old 10-23-2013, 10:21 PM
Drewski 2's Avatar
Quote:
I had leaned toward another aluminum panel, but I'm also going to do a console and I would like to incorporate some wood panels in it also. My build is a budget build and I just happen to have wood left over from other projects.
I think the matching wood would look great on your truck.
Old 10-23-2013, 10:57 PM
ha ha, mine is a budget build as well. It keeps taking more of my budget.
Old 10-23-2013, 11:00 PM
Drewski 2's Avatar
Home brewed running boards
A lot of you guys have seen this before so bear with me.....I'm checking to see how easy it is to copy paste old posts.
I had originally intended to use the stock looking ribbed running boards on my truck, but decided that the look didn't fit the truck. I decided to take a shot at making my own boards.
Using masonite and wood, I mocked up the shape I wanted.
Transferred the shape of the pattern to my metal blanks.
Lots of cutting, welding and grinding.
I had decided to exit the exhaust through the running board, so I fabbed a ring that would be used to form the character of the exhaust opening.
I had to extend the bottom edge of the board to make the exit point look correct. If I had this to do over I would have incorporated the extra material in my board blanks to avoid the extra welding.
Lots of smoothing, priming, and blocking.
It was a bunch of work, but cheap to build and not like everybody else. In hindsight, I would have tapered the running boards from where the exhaust exits all the way to the front where the board meets the front fender.
Old 10-24-2013, 07:01 AM
jimcar-9 jimcar-9 is offline
jimcar-9 has a good reputation on FTE.jimcar-9 has a good reputation on FTE.jimcar-9 has a good reputation on FTE.
I dont really know if this qualifies as fabrication but what the heck??
DinnerHill SpeedShop: Construction of KPH scale
DinnerHill SpeedShop: Speedometer
Old 10-24-2013, 08:42 AM
oldmerc's Avatar
oldmerc oldmerc is offline
oldmerc
oldmerc is a name known to alloldmerc is a name known to alloldmerc is a name known to alloldmerc is a name known to alloldmerc is a name known to alloldmerc is a name known to all
Heres one . I needed a new battery box
Old 10-24-2013, 09:27 AM
tinman52's Avatar
tinman52 tinman52 is offline
Welder User
tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.
I have to fab stuff almost for vehicles almost daily it seems.
One of the more fun projects was building a sheet metal break. I made it from steel I had laying around, it will bend 18 ga 4 foot wide. It could use some counterweights though if I ever get around to it...
Old 10-24-2013, 09:55 AM
ChuckRob's Avatar
ChuckRob ChuckRob is offline
ChuckRob has a great reputation on FTE.ChuckRob has a great reputation on FTE.ChuckRob has a great reputation on FTE.ChuckRob has a great reputation on FTE.ChuckRob has a great reputation on FTE.
I needed to make mounts for my bucket seats. I wanted to be able to remove the seats quickly so that I could work under the dash.
Old 10-24-2013, 11:47 AM
CharlieLed's Avatar
CharlieLed CharlieLed is offline
CharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud of
Complete core support setup for my 56 (and a Chevy bumper)...
Tonneau Cover Recommendations... VH_Girl 1999 - 2003 7.3L Power Stroke Diesel 22 11-27-2011 12:33 PM
HELP! F450 TAIL AND BRAKE LIGHTS NOT WORKING Bill Conner 1999 - 2003 7.3L Power Stroke Diesel 6 04-30-2011 11:56 PM
1968 F600 4X4 Brakes Steilenberg 1967 - 1972 F-100 & Larger F-Series Trucks 3 09-13-2008 09:34 AM
Bagging a 65? ByondControl 1961 - 1966 F-100 & Larger F-Series Trucks 15 09-11-2008 01:52 AM
3 Speed manual trans ID FreakinFord 1967 - 1972 F-100 & Larger F-Series Trucks 4 01-03-2008 07:22 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
