FABRICATION!! We want to see what you've built. - Page 5 - Ford Truck Enthusiasts Forums
  #61
Old 02-21-2014, 09:31 AM
bobj49f2's Avatar
bobj49f2 bobj49f2 is offline
bobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud of
Drew saw my post on another thread and suggested that I should put the picture up here about the pair of rusty fenders I bought a few weeks ago.
Here's what I got and what I'm have been doing the last few nights. You dry, sunny southwestern guys can stop laughing and go to another post. Up here in the rust belt these are considered normal, not really desired, but normal.
I started on the right fender. It looked like someone must have had some kind of rack bolted to this fender and it got caught on something. Their were three 1/2" bolt holes and a nice 1/2" deep crease in the upper fender. There was also the normal rust.
Hammered out the dent.
Made a patch panel for the rust out on the side of the fender.
Welded the hole closed and welded in the patch.
The inside support piece was rotted so I made a new one, I used a bent bolt, hammer and my bench vice to form the bead.
The front of the fender and bottom matting surface was also pretty far gone so I cut out the rusted metal, made a patch and welded it in. The front patch took a little time because it has a compound curve I had to shape.
I know some will think I'm wasting time on a set of fenders that are so far gone but I wanted to let people know that sometimes even the worst looking fenders can be saved. I also like a challenge and repairing rust.
  #62
Old 02-21-2014, 09:39 AM
jimcar-9 jimcar-9 is offline
jimcar-9 has a good reputation on FTE.jimcar-9 has a good reputation on FTE.jimcar-9 has a good reputation on FTE.
Wow Nice work! I wouldn´t call that a waste! any day of the week
  #63
Old 02-21-2014, 10:26 AM
gregstith's Avatar
gregstith gregstith is offline
gregstith is gaining momentum as a positive member of FTE.gregstith is gaining momentum as a positive member of FTE.
Excellent work Bob!! Much more satisfying than just bolting on a new fender. Cheaper too!
  #64
Old 02-21-2014, 07:49 PM
19fifty4 19fifty4 is offline
19fifty4 has much to be proud of19fifty4 has much to be proud of19fifty4 has much to be proud of19fifty4 has much to be proud of19fifty4 has much to be proud of19fifty4 has much to be proud of19fifty4 has much to be proud of19fifty4 has much to be proud of19fifty4 has much to be proud of
Bob, that's impressive! Well done. Thanks for posting.
  #65
Old 02-21-2014, 08:32 PM
topmoo's Avatar
topmoo topmoo is offline
topmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant future
Looks like works of art! Very nice, you make it look easy.
  #66
Old 04-19-2014, 08:30 PM
Wayne Waldrep's Avatar
Wayne Waldrep Wayne Waldrep is offline
Wayne Waldrep has a very good reputation on FTE.Wayne Waldrep has a very good reputation on FTE.Wayne Waldrep has a very good reputation on FTE.Wayne Waldrep has a very good reputation on FTE.
My creation..
Well this isn't truck related but metal fab. I was pulling this off my bike today and this thread came to mind. Best I know to do is post this link and let you guys check it out on my motorcycle forum. Hope you enjoy as I know there are quite a few fellow bikers on here.....
Fabbed a Backrest Thingy.... - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
  #67
Old 04-19-2014, 09:17 PM
bobj49f2's Avatar
Not specifically old Ford truck related but it is something I made for my other project, my 1937 Buick.
The grills on these cars are made of pot metal and are prone to break into two pieces and like any other pot metal piece they deteriorate over time. To find an unbroken set with good chrome is getting impossible after 70 years. Some time back someone made reproduction pieces out of aluminum but they also don't fare well in the front of a car bouncing down the road.
Here's my solution made out of stainless steel, these should last forever, at least longer than the owner and car. There are 41 horizontal slats, 15 different lengths with a curve and the grill has a slight outward belly with a twist. I give a lot of thanks to Chris Freeman for helping make a welding jib to make these, well he did most of the work, I just got in the way:
  #68
Old 04-20-2014, 01:17 AM
Jules The Great Jules The Great is offline
Jules The Great is gaining momentum as a positive member of FTE.Jules The Great is gaining momentum as a positive member of FTE.
Brake caliper mounting brackets I made to hold 1995 F250 calipers.
  #69
Old 04-20-2014, 07:39 AM
49willard 49willard is online now
49willard has a great reputation on FTE.49willard has a great reputation on FTE.49willard has a great reputation on FTE.49willard has a great reputation on FTE.
Very well done. Hats off to you and Chris!
  #70
Old 04-20-2014, 10:59 AM
bobbytnm's Avatar
bobbytnm bobbytnm is offline
Roast em' if you got 'em
bobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud of
Nice work guys!!!
Here's my latest. I recently fabricated a lower dash panel to house my heater control panel, headlight switch, and ignition switch. Here's what I came up with;
More details in this thread;
http://www.ford-trucks.com/forums/12...-progress.html
Thanks
Bobby
  #71
Old 04-20-2014, 11:26 AM
firstrider's Avatar
firstrider firstrider is offline
firstrider has a great reputation on FTE.firstrider has a great reputation on FTE.firstrider has a great reputation on FTE.firstrider has a great reputation on FTE.firstrider has a great reputation on FTE.firstrider has a great reputation on FTE.
Magic Air heater cover part
The small top vent pc. was missing from a Magic Air heater cover so one was fabbed from a pc. of sheet metal. Made a pattern out of tag board first. The hardest part was visualizing what it looked like flat & making the bends in the correct order .
Had 7 heater covers w/ fins missing so made some new ones a fuzz wider , used dremel to make very small slits in side of cover & secured not by welding . Tried that , it did not work .JB weld did the trick .
Heater cover had fin area messed up . Another cover had a large hole in the front where some one attached a 12 V motor & it stuck out the front but had all the fin areas good . So indexed the cover area on both ,cut out the good face and welded to the other .Placement was critical as it centers the motor in the housing . Checked it & was good .
  #72
Old 04-20-2014, 06:26 PM
Lakotas53's Avatar
Lakotas53 Lakotas53 is offline
Lakotas53 is starting off with a positive reputation.
I had to do a little fab work to the cowls and cab corners. Drivers side was the worst.
EDIT: I did something wrong, suppose to be pictures attached.
  #73
Old 04-20-2014, 07:54 PM
Gicknordon's Avatar
Gicknordon Gicknordon is offline
Gicknordon is a name known to allGicknordon is a name known to allGicknordon is a name known to allGicknordon is a name known to allGicknordon is a name known to allGicknordon is a name known to all
This is an older picture but its the part im probably most proud of as far as fabricating. The bars and sway bar were bought it a kit but i made the cross members and notch.
  #74
Old 04-20-2014, 10:09 PM
NapaRick NapaRick is offline
NapaRick is starting off with a positive reputation.
The previous owner covered the speaker hole with a piece of sheetmetal
which he screwed to the dashboard. Since I am in the middle of rewiring
the truck and I needed a place to mount the fuses and relays, I made this.
BEFORE
THIS IS THE FUSE PANEL BRACKET. I MADE IT OUT OF AN ALUMINUM
DOOR KICK PLATE!
FUSE PANEL MOUNTED. I COVERED THE ALUMINUM IN SEVERAL LAYERS
IN DUCT TAPE FOR INSULATION.
ACCESSORY SPEAKER COVER I GOT FROM VINTAGE FORD IN SACRAMENTO
WOOD SCREWS AND INSERT NUTS FROM THE HARDWARE STORE
I SCREWED THE STUDS INTO THE PLASTIC AND THE NUTS ARE EASY
TO SCREW ON AND OFF. IT IS VERY EASY TO REACH UNDER THE DASH
AND UNSCREW THEM WITH MY FINGERS SO THE PLATE CAN COME ON
AND OFF VERY EASILY.
HERE IT IS. TERRIBLE PHOTO BUT YOU GET THE IDEA
  #75
Old 04-21-2014, 09:33 PM
truckeemtnfords truckeemtnfords is online now
truckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to behold
That is good that it comes apart easy, 'cuz I would never use duct tape for anything like you did. Once the dash gets hot in the Napa summer sun it will be a big gooey mess. If you must wrap it with something why not electrical tape? Other than that it looks like a great job.
Tonneau Cover Recommendations... VH_Girl 1999 - 2003 7.3L Power Stroke Diesel 22 11-27-2011 12:33 PM
HELP! F450 TAIL AND BRAKE LIGHTS NOT WORKING Bill Conner 1999 - 2003 7.3L Power Stroke Diesel 6 04-30-2011 11:56 PM
1968 F600 4X4 Brakes Steilenberg 1967 - 1972 F-100 & Larger F-Series Trucks 3 09-13-2008 09:34 AM
Bagging a 65? ByondControl 1961 - 1966 F-100 & Larger F-Series Trucks 15 09-11-2008 01:52 AM
3 Speed manual trans ID FreakinFord 1967 - 1972 F-100 & Larger F-Series Trucks 4 01-03-2008 07:22 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
