FABRICATION!! We want to see what you've built. - Page 4 - Ford Truck Enthusiasts Forums
  #46
Old 11-14-2013, 09:29 PM
topmoo's Avatar
topmoo topmoo is online now
topmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant future
Quote:
Originally Posted by 56 Big Window View Post
Sheeeeit...Nothing wrong with that, my friend! Pretty ingenious, if you ask me! Funny no one sells an attachment like that. Maybe you ought to look into patenting and marketing it...seriously!
Bernard
Agreed! That is a very clever devise and very portable.
  #47
Old 02-14-2014, 07:32 PM
Drewski 2's Avatar
Drewski 2 Drewski 2 is offline
Drewski 2 has much to be proud ofDrewski 2 has much to be proud ofDrewski 2 has much to be proud ofDrewski 2 has much to be proud ofDrewski 2 has much to be proud ofDrewski 2 has much to be proud ofDrewski 2 has much to be proud ofDrewski 2 has much to be proud of
This thread seems to have died, so I'll bring it back up with an item I use in fabrication. Robbed from my pile of firewood a few years back. I beat on metal on it, hang hammer from it and if nothing else sit on it. Got cheap HF casters so I can roll it around.
  #48
Old 02-14-2014, 07:41 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
Looks like nice hardwood! Next time I'm back east I need to pick up some. Pine and cottonwood aren't much good.
  #49
Old 02-14-2014, 08:05 PM
Drewski 2's Avatar
Quote:
Yeah, softwoods don't work too well when you're trying to whip a shape into a piece of metal. I'd send you a nice big chunk out, but they are darn heavy.
  #50
Old 02-14-2014, 09:15 PM
tinman52's Avatar
tinman52 tinman52 is online now
Welder User
tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.
Drew, what did you use to hollow out the center? Circular saw?
I need to make one...
  #51
Old 02-14-2014, 09:52 PM
Drewski 2's Avatar
I've got one of those attachments that fits my 4 1/2" grinder that basically is a circular chain saw blade. It makes really quick work at carving out the hollow area. Really have to be careful with it as I suspect it would remove a finger before you know what happened.
I have used a circular saw on some of my other stumps to create the hollow area.
After I get the hollow shape, I use a DA to fine tune it and smooth it up.
  #52
Old 02-14-2014, 10:17 PM
topmoo's Avatar
It looks like a piece of spalted maple. Nice.
  #53
Old 02-15-2014, 09:38 AM
Drewski 2's Avatar
Quote:
To be perfectly honest, I'm not sure what the one in the picture is. This particular one just happens to have some nice visual effects to go along with it's utility. I usually replace them every so often due to the cracks and splits that occur in them. I keep a fairly heavy coat of tung oil on them to slow down the effects of a very dry shop on a piece of wood that is not dry. The one I have now has been around for about 3 years and cracking has been minimal.
  #54
Old 02-15-2014, 09:42 AM
48 Steel's Avatar
48 Steel 48 Steel is offline
48 Steel is a splendid one to behold48 Steel is a splendid one to behold48 Steel is a splendid one to behold48 Steel is a splendid one to behold48 Steel is a splendid one to behold48 Steel is a splendid one to behold
Here is a list of my build.
Fabricated parts: 12" roll pan, frenched license plate, tailgate hinges, tonneau & latching cover, reversed hood hardware, IFS mounts, radiator mount, wing window guides, taillight mounts, transmission & motor mounts, shock tower mounts, frame boxing plates, stainless heat/cool control mount.
Modified parts: Extended rear fenders, doors, running boards, grille, hood, bed, lower valance, fire wall, cab, windows, frame, cowl, dash.
Catalog after market parts: Tailgate, running boards, transmission tunnel, IRS mounts, hidden hinges.
________________________________________
48 Ford F1 - Darkside
46 Ford Tudor - Street Rod
"True Hot Rods have 3 pedals"
  #55
Old 02-15-2014, 09:59 AM
Drewski 2's Avatar
Quote:
Fabricated parts: 12" roll pan, frenched license plate, tailgate hinges, tonneau & latching cover, reversed hood hardware, IFS mounts, radiator mount, wing window guides, stainless heat/cool control mount.
Sooooo......when are you going to fabricate something?????
Kidding...I've been tracking your build on different forums for some time. You've laid hands on about every square inch of that truck. Nice work!!
  #56
Old 02-15-2014, 10:32 AM
48 Steel's Avatar
I think the only Stock parts on this build are the front fenders. As much as I love fabrication it's great to be on the downhill side of the build. I will be finished this summer and I will start a Built thread here after it is finished. This has been a labor intensive project as I'm sure you know what that means. We (FTE's) love our trucks and it shows in what we do. I'm on a few forums but this one is by far the BEST.
"A little spark, a little coil, a little gas, a little oil, a piece of tin, a piece of board, put that together and you've got a Ford (Ed Roth)"
  #57
Old 02-16-2014, 12:13 AM
old_dan's Avatar
old_dan old_dan is offline
old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.
I did this rear bumper last year. I used the profile of the front bumper, even though it is mitered and not curved.
I finished it off with some LED tail lights and black powder coating.
  #58
Old 02-16-2014, 11:07 AM
bobbytnm's Avatar
bobbytnm bobbytnm is offline
Roast em' if you got 'em
bobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud of
Wow!!
Nice job on that bumper!! That looks really great
Bobby
  #59
Old 02-16-2014, 11:14 AM
19fifty4 19fifty4 is offline
19fifty4 has much to be proud of19fifty4 has much to be proud of19fifty4 has much to be proud of19fifty4 has much to be proud of19fifty4 has much to be proud of19fifty4 has much to be proud of19fifty4 has much to be proud of19fifty4 has much to be proud of19fifty4 has much to be proud of
Great job on the bumper. Those are the fab pics I love to see. Well done!
  #60
Old 02-16-2014, 11:33 AM
Olweldinrig's Avatar
Olweldinrig Olweldinrig is offline
Olweldinrig is gaining momentum as a positive member of FTE.Olweldinrig is gaining momentum as a positive member of FTE.
I am Subscribeing,There is some awfully nice stuff being made here!!
Tonneau Cover Recommendations... VH_Girl 1999 - 2003 7.3L Power Stroke Diesel 22 11-27-2011 12:33 PM
HELP! F450 TAIL AND BRAKE LIGHTS NOT WORKING Bill Conner 1999 - 2003 7.3L Power Stroke Diesel 6 04-30-2011 11:56 PM
1968 F600 4X4 Brakes Steilenberg 1967 - 1972 F-100 & Larger F-Series Trucks 3 09-13-2008 09:34 AM
Bagging a 65? ByondControl 1961 - 1966 F-100 & Larger F-Series Trucks 15 09-11-2008 01:52 AM
3 Speed manual trans ID FreakinFord 1967 - 1972 F-100 & Larger F-Series Trucks 4 01-03-2008 07:22 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
