FABRICATION!! We want to see what you've built. - Page 2 - Ford Truck Enthusiasts Forums
Old 10-24-2013, 12:25 PM
cdl2374's Avatar
cdl2374 cdl2374 is offline
cdl2374 has a good reputation on FTE.cdl2374 has a good reputation on FTE.
I like it! Looks good..
Old 10-24-2013, 03:44 PM
Rimrock F1's Avatar
Rimrock F1 Rimrock F1 is offline
Rimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud of
I don't want to single any one person out so I'll just say. Some of the abilities and workmanship shown on this board is astounding. Way to go guy's
Old 10-24-2013, 03:54 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe Jolly Roger Joe is offline
Just another Joe
Jolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud of
Quote:
Yeah, when I grow up I want to develop skills like some of these fellows possess.
Old 10-24-2013, 04:41 PM
Drewski 2's Avatar
Drewski 2 Drewski 2 is offline
Drewski 2 has much to be proud ofDrewski 2 has much to be proud ofDrewski 2 has much to be proud ofDrewski 2 has much to be proud ofDrewski 2 has much to be proud ofDrewski 2 has much to be proud ofDrewski 2 has much to be proud ofDrewski 2 has much to be proud of
Quote:
Originally Posted by tinman52 View Post
I have to fab stuff almost for vehicles almost daily it seems.
One of the more fun projects was building a sheet metal break. I made it from steel I had laying around, it will bend 18 ga 4 foot wide. It could use some counterweights though if I ever get around to it...
Any details on the metal brake? Looks good. I built a brake based on something from a Mother Earth News magazine about 30 years ago but it's not quite as refined as yours appears to be.
Old 10-24-2013, 05:05 PM
das54's Avatar
das54 das54 is offline
das54 has a very good reputation on FTE.das54 has a very good reputation on FTE.das54 has a very good reputation on FTE.
+1 Mike and Joe's comment about the fabulous fab projects some here have done. My examples are like Doods54. But I'll post my hanging brake pedal bracket. From a 77 Chevy with extension top and bottom to get to the top and bottom fire wall pinch seams and a strut to the bottom of the dash. Seems plenty stout. Some day I might remove the arm, cut off the pedal and weld on a heavy nut to attach the oem pedal.
Old 10-24-2013, 05:32 PM
48_F1's Avatar
48_F1 48_F1 is offline
48_F1 is starting off with a positive reputation.
some simple yet effective firewall patches ratrod style (no, it's not an excuse for lazy fabwork I'm going for that look)
Old 10-24-2013, 08:08 PM
GB SISSON's Avatar
GB SISSON GB SISSON is offline
GB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant future
I think the rat rod guys today saw what we did many years ago and copy things like firewall patches and less than perfect welds. We called it 'fixing stuff'....... We didn't know there would someday be 'rat rods'. Nice fab work, all of you.
Old 10-24-2013, 09:12 PM
tinman52's Avatar
tinman52 tinman52 is online now
Welder User
tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.
Quote:
Actually I was just kinda winging it.....it is pretty simply built, the base is a couple pieces of 8" channel. The clamp is a piece of grader blade (cutting edge), and the tipping blade is 5/8x 4". Spring loaded clamps are large bolts.
Old 10-24-2013, 09:45 PM
oldmerc's Avatar
oldmerc oldmerc is offline
oldmerc
oldmerc is a name known to alloldmerc is a name known to alloldmerc is a name known to alloldmerc is a name known to alloldmerc is a name known to alloldmerc is a name known to all
Home made xmember for my T5
Old 10-24-2013, 10:52 PM
smallello's Avatar
smallello smallello is offline
smallello has a great reputation on FTE.smallello has a great reputation on FTE.smallello has a great reputation on FTE.smallello has a great reputation on FTE.
Not a major fabrication but - I made bed roll lights.
http://www.ford-trucks.com/forums/11...ll-lights.html
Old 10-25-2013, 01:06 AM
AXracer's Avatar
AXracer AXracer is offline
AXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud of
I have several fabrication projects documented in my galleries (click on my user name at the top of any of my posts, select view gallery, select appropriate gallery) but here's one reposted:
Repro LED caddy tailights frenched in the rear fenders of my 56 panel
1. building 16 ga bucket around wood buck
2. Making sure top is same size/shape as bottom after welding:
3. Frame ready to have base welded in:
4. Wood buck, LED taillight, finished bucket:
5.Deciding on placement:
6. Body opening cut. Note raised OEM taillight mount area not yet shaved, filled.
7. Bucket inset and angle determined, body line traced on outside of bucket:
8. Bucket skip tacked to body opening:
9, Original raised mount area cut away, shaped patch fitted:
10. bucket and patch completely welded, excess bucket ground smooth, inside corners being rounded with die grinder:
11. Locating any high or low spots with body (vixen) file:
12. Metal finishing nearly complete. Just a couple small low spots to raise up and a skim coat of putty to finish.
13. Pass side done same way. Test fitting taillight:
Old 10-25-2013, 10:21 AM
51PanelMan's Avatar
51PanelMan 51PanelMan is offline
51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all
^^^^^I remember that post. That was a loooong time ago.
  #28
Old 10-25-2013, 10:51 AM
Drewski 2's Avatar
[quote=AXracer;13664665]I have several fabrication projects documented in my galleries (click on my user name at the top of any of my posts, select view gallery, select appropriate gallery) but here's one reposted:
Ax, thanks for the re-post. I've spent countless hours going through galleries looking for fabrication projects like yours and I thought this thread would highlight a variety of fabrication projects done by different builders.
I know that there are a lot of interesting fabrication projects hidden in the galleries, but I don't get a lot of positive results using the search features.
  #29
Old 10-25-2013, 12:06 PM
GB SISSON's Avatar
Installed a sterling 10 1/4 rear from a '92 F350 under my '59 F350. Had to move the existing spring mounts about 1 1/2", while keeping same driveline angle. Then I modified the driveshaft length by using about 10" of the '92s shaft telescoped over the cut-off end of the 59's. The eight 1/4-20 round head stove bolts provided perfect spacers for aligning the two. I could not slide them together without light tapping with a brass hammer. At the open end where dissimilar diameters presented a welding challange, I took a ring off a piece of steel pipe and removed the weld line inside with a die grinder, then tapped it up the smaller shaft. I tacked it in place and needed to taper this ring so it would engage part way into the larger shaft. There was a 4 speed 'lathe', powered by a six cylinder engine mounted in just the right place. Thus, I engaged second gear and using an angle grinder, tapered my ring with a trial and error fit. Next, being very careful to keep the u-joins in sync, I welded it up. The inside of the ring to the small shaft, the outside of the ring to the larger shaft. I know driveline work is fairly cheap, but so am I. As for safety, all I can think of for failure is my weld fails, and the two shafts slide within each other and I roll to a stop. Thinking a 3" dia shaft has about 9"+ of weld around it to shear. At 60, no vibration I can detect......
  #30
Old 10-26-2013, 09:12 AM
GreatNorthWoods's Avatar
GreatNorthWoods GreatNorthWoods is offline
GreatNorthWoods has a great reputation on FTE.GreatNorthWoods has a great reputation on FTE.GreatNorthWoods has a great reputation on FTE.GreatNorthWoods has a great reputation on FTE.GreatNorthWoods has a great reputation on FTE.
My most recent fabrication involved making this bracket to fit a Chrysler PS pump (since I'm using a Volare suspension) to the front of a 302 Ford engine...
Dual Battery Disconnect bismic 6.0L Power Stroke Diesel 8 04-09-2015 01:47 AM
Cummins conversion Steilenberg Kentucky Chapter 2 10-24-2008 08:03 PM
Closing in.... - KY Steilenberg New Member Introductions 2 10-18-2008 06:42 PM
AC issue - Explorer DeluxF150 Explorer, Sport Trac, Mountaineer & Aviator 12 10-11-2008 04:56 PM
Windshield noise Nibs 2004 - 2008 F150 16 01-22-2007 07:11 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
