1982 F100 3 speed manual transmission identification
I have a 1982 F-100 2wd with a 300 six cylinder and a three speed column shift manual transmission. The transmission recently became very noisy. I am looking to find a good used one to replace it or possibly rebuild the original. What is this type of transmission called and what years would interchange? Any help is appreciated. Thanks, Brian.
Its a 303 ford 3spd .Sounds like you need the input and output bearings replaced.I'd put a 435 new proccess in if I was replacing trans .Measure length of 3 spd if you find a 4spd measure length of it .If you can get the drive shafts that came with the 4spd that be the way to go .There may be a differance in drive shaft lengths .I'M thinking they may be the same but I would do some measuring to be sure
bluesalomon
11-27-2017 08:06 PM
Jakemcswaggins
01-18-2017 10:27 PM
rs422a
10-24-2010 10:12 AM
83f100ss
13
01-11-2004 11:26 PM
