Help..Truck Pulls hard to the left
Hello,
Im a first time user on this site and I already have a question for you experts. Well, here goes. I just changed out my brake rotors and pads(front) bled the brakes and the truck (94 F-250 2WD) pulls way hard to the left....I pull a camper and I think this condition is unsafe..Any Ideas? Iread in my Chiltons that ther is a Pressure differential valve that should be centeres...do I have one and should I and how do I center it...Could that be the problem...Help!!!
Thanks in Advance
Tom
Thanks in Advance
Tom
one day offroading i broke one side of my steering linkage, tie rod and everything, one side is new and the other is factory i pull real hard to the right because one wheel is kicked out it is fixable but it is going to have to take a professional (waiting for spacers to go in then will try to fix it)the alignment guy who did it said if you change anything that has to do with steering it is going to mess it up, damn i beams
