1968 F350 crew cab - Ford Truck Enthusiasts Forums
1968 F350 crew cab
Old 10-23-2013, 01:28 PM
ltharper's Avatar
ltharper ltharper is offline
ltharper is starting off with a positive reputation.
1968 F350 crew cab
Hi y'all. Im new to the forum. I recently bought a 1968 Ford F350 Crew Cab dually. It was originally a paving company's truck as the lettering can still be seen on the side. It had a pintle hitch on the back at some point of time so I assumed it towed alot. It has a 390 in it, that was running when I bought it, but is not now (long story). It even has front disc brakes. I was wondering if any of y'all know of any good resources for crew cab parts. I live in eastern NC. I have an AC unit out of a '66 that I am going to try to install in it, I am planning on getting the engine rebuilt. Im going to put a flat bed on it and probably some bucket seats on the inside. The outside only has one dent in the back door and a small amount of rust on the bottom of the other back door.Y'all got any suggestions on what to do with it or where to get parts (besides LMC). Im in college so Im going to try to get it running for as cheap as possible. I deal alot more with diesel motors and don't know a lot about gas motors. Any help or suggestions would be great. Thanks!
Old 10-23-2013, 02:05 PM
abyars111's Avatar
abyars111 abyars111 is offline
abyars111 is starting off with a positive reputation.
Welcome aboard. The only "special" I've found so far on my crew cab are the cab, rear doors & under bed aux. fuel tank. The doors are actually cut down front doors as well as the door panels. You can buy parts from any Bumpside parts dealer. NPD, Carpenters, Carolina Classics. You can still get a lot of NOS Ford parts from dealers such as Green Sales.
Check out www.oldfordcrewcabs.com It is a good website for crew cab info but you can get much better than this website.
Old 10-23-2013, 03:08 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
I have an AC unit out of a '66 that I am going to try to install in it.
Dual piston caliper disc brakes were an option for 1968/72 F250 2WD's & F350's.
The only A/C available for 1965/67 F100/350's came w/a "hang-on" bezel that contains the blower motor and expansion valve.
Bezel is the same as 1965/66 Mustang, its face has four round registers with the two A/C switches between them.
While picture caption includes 1968/69, rarely will this A/C be found in these trucks, plus...352's were not installed after 1967.
Beginning in 1968, Ford offered three different A/C's, all were hang-on units.
1) Factory installed integral A/C combined w/the heater, A/C controls located in same panel as heater controls.
2) Deluxe dealer installed A/C, bezel spans the entire underside of the dash, contains two switches.
3) Economy dealer installed A/C, bezel located at center of dash, contains two switches.
Old 10-23-2013, 03:40 PM
ltharper's Avatar
Thanks for all the info.my truck has an under the bed aux. Tank but i dont think its any good. Gotta take it off and check it out when I go home next time. The a/c system is a hang on system. I dont kbow if it will put out enough to matter because i have never seen it work. It came off of an old parts truck we used to have.
Old 10-23-2013, 05:43 PM
abe's Avatar
abe abe is offline
abe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud of
We like old work trucks with old lettering on... so you got to show us some pictures!
and welcome to FTE!
Old 10-23-2013, 05:51 PM
ltharper's Avatar
The lettering is either painted over or removed decals. You csn just barely see the outline of it. But I will tryto put some pics up
Old 10-23-2013, 08:37 PM
ltharper's Avatar
Heres some pics of the truck. theyre not really good, but im an hour away from the
[IMG]http://s749.photobucket.com/user/ltharper/media/dually6_zps1beda44d.jpg.html?sort=3&o=4[/IMG
Old 10-23-2013, 08:58 PM
crazed87bronco's Avatar
crazed87bronco crazed87bronco is offline
crazed87bronco is gaining momentum as a positive member of FTE.
Not sure if its just me but I can't see any photos just blank boxes good find on the crew cab what all parts are you looking for it?
Old 10-23-2013, 09:03 PM
abyars111's Avatar
pictures don't show up for me either but I pasted your link in my browser and it worked.
dually6_zps1beda44d.jpg Photo by ltharper | Photobucket
this link should take anyone to the pics
that looks like a good solid find
nice score
My family & I love our crew cab, everyone gets to ride
Old 10-23-2013, 10:00 PM
ltharper's Avatar
Sorry bout the pics. Im still getting used to the forum. Im looking for a headliner, carpet, small things like that mostly. the truck is pretty complete. Even the dome light works. I do need a new grill as it looks like the previous owner maybe hit a deer or something. I would like to do a swap to a '70 or newer grill, but all of that will have to wait until I get the engine rebuilt, unless I find a good deal on something. I am possibly looking a stock longbed. I thought about adding some fiberglass fenders to a stock bed maybe by using some fenders from arrocraft for a 92-96 truck. I believe they will bolt right on.
Old 10-23-2013, 10:08 PM
abyars111's Avatar
you hit on an something I forgot to mention, the headliner is a crew cab only item, you'll have to fabricate something
The Dentside carpets fit in the Bumpside crew cabs. Some venders list them seperate but most only list the 1973-1979 version withc will fit.
Old 10-23-2013, 10:31 PM
Yea abyars is right on the headliner and carpet you won't find a headliner unless you get it from a donor crew. I got a question for my fellow crew owners did anyone else's bump side crew come from FACTORY with a full carpet? Mine didn't come with a carpet but did have a rubber type mat covering the whole floor. It's a shame my buddy found a crew wasted away in a field and he scrapped it but let me pick what I wanted off of it first i got a couple parts and told him to get me the headliner but he forgot to get it I was sad to see a nice condition liner go to waste. Pretty much anything that separates a standard cab from being a crew cab is not offered in reproduction parts you'll need to make your own very clean crew you have there mine was Swiss cheese still is in spots but I like these old fords in yellow and orange color
Old 10-23-2013, 10:41 PM
bigbrown1985 bigbrown1985 is offline
bigbrown1985 is starting off with a positive reputation.
Go to national parts depot every cab configuration and color only like 200 fully molded carpet kits!
Old 10-23-2013, 11:15 PM
Ill have to check into that site I got a carpet set for my crew but forget if it was for a standard cab or a crew cab from Lmc been so long since I ordered it. anyone ever try making a new headliner? Would like to see how you's did it been thinking of trying to make one up looking for ideas
Old 10-23-2013, 11:30 PM
I was thinking of using 1/8 inch Masonite board then covering it.
1978 F350 Crew Cab 1978crewcab Vehicles for Sale 4 01-13-2017 04:14 PM
97 f250 crew cab 7.3 PSD how much can I tow? jperry1213 Fifth Wheel & Gooseneck RV Towing 6 09-11-2016 04:09 PM
06 rear power sliding window not operational CG-ITS 1999 to 2016 Super Duty 4 02-21-2016 10:53 AM
1972 f-350 crew cab mitchell390 1967 - 1972 F-100 & Larger F-Series Trucks 21 05-01-2012 08:18 PM
Crew Cab Length Festus Hagen 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 04-16-2009 10:52 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
