P2099....OK!! - Ford Truck Enthusiasts Forums
P2099....OK!!
Old 10-23-2013, 11:46 AM
fluidp fluidp is offline
fluidp is starting off with a positive reputation.
P2099....OK!!
Here the story. 06 F350 6.0 PSD 6 speed manual, never chipped, completely stock, 260 km, oil and filter changes before due, don't drive hard, rarely hit 3000 rpm
Had warrantee till a couple months ago, past 3 years 4 injectors, and a blown turbo. The past 20 k ran great
I decided to keep her rather then buy new, so bodywork and full paint was just done, Front end work, incl. BDS duel steering stabilisers.
Just took for test drive yesterday after installing stabilisers and it seemed very sluggish, no get up and go, turbo boost seemed to be there but no jump.
Went for a longer run to town, ran ok for 10 k and then the loss of power thing. made a stop and went to start.... no start.. wait a min start right up. Drive away but something is wrong... no power
Made another stop and it started right up, while idle for 10 sec, idle went real slow and then stalled, Engine light came on
waited a min, started right up, had a couple more starts and stops before heading home, one more stall and loss of power for 40 k drive.
Got home got the P2099
Heres the thing...I am going to be doing a lot of highway driving in the next few months.
Should I just get the HPOP, IPR , IPC, and maybe a new set of injectors.
Any suggestions would be a big help, I don't mind doing the work myself, as I have done extensive PSD work on the first generation PSD`s
I guess it might be time to dive into this one...
Old 10-23-2013, 04:11 PM
Just talked to my PSD mechanic (X ford tec gone independent) He said more then likely oil leaking by. Suggested isolate HPOP from oil galleries and preasure test galleries. If Galleries test ok, HPOP probably blowing by. If preasure test shows leak in galleries, probably a o-ring somewhere, injectors perhaps.
For the $$ I might have to spend on labour im thinkin about diving into it my self. I have the time now.
The last major PSD work I did was on my 94, 95 PSD 7.3. Pulled the IDI out of my 94 and installed a PSD in it. Huge job!! Wire harness under dash.. even the windshield wiper motor had to be changes because of a different plug..
Any way , I probably going to be asking a few questions along the way.
Ill try to get some pics up as I go.
Old 10-23-2013, 04:29 PM
BLADE35's Avatar
BLADE35 BLADE35 is offline
BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.
Was the DTC P0299
SOunds like a Stuck Turbo unison ring Very common if they Sit for long periods
Check BARO,MAP,EBP
05+ is common to have HPO Problems with everything BUT the Pump
You need to Post ICP--ICPV--IPR%
Old 10-23-2013, 05:06 PM
99ExpyProblems 99ExpyProblems is offline
99ExpyProblems has a very good reputation on FTE.99ExpyProblems has a very good reputation on FTE.99ExpyProblems has a very good reputation on FTE.99ExpyProblems has a very good reputation on FTE.
P0299 Need to monitor VGT while driving down the road. I'll see if I can find the video that tells you how to monitor/test. Probably have to just do what BLADE said and pull the turbo and clean it.
Edit: Here is the video
Old 10-23-2013, 06:38 PM
CPB1's Avatar
CPB1 CPB1 is offline
CPB1 is a splendid one to beholdCPB1 is a splendid one to beholdCPB1 is a splendid one to beholdCPB1 is a splendid one to beholdCPB1 is a splendid one to beholdCPB1 is a splendid one to behold
These vids are great, I learn something from every one. Thanks Bill <<< because I can't rep you.
Yea, I think he means P0299, I don't have anything for P2099.
Old 10-23-2013, 10:09 PM
Sorry All P2290
Old 10-23-2013, 10:12 PM
iNJECTOR PREASURE LOW
Old 10-23-2013, 10:18 PM
BLADE35's Avatar
Quote:
Originally Posted by fluidp View Post
Sorry All P2290
OK lets go in a different direction LOL
HPO SYSTEM problem
Got a Gauge to read ICP ICPV IIPR% ?????
P2290 ICP Injector Control Pressure Too Low Actual pressure is less than commanded for a specified time
P2290 - Fault sets when actual pressure is less than the commanded by a specified value (3.0MPa)
Old 10-23-2013, 11:00 PM
I have no gauges other then stock.
What gauges should I purchase
Given my truck has 250 km on it I feel that a rebuild of the top end ( hpop, ipr, injectors etc) would be worth while
I also need a scanner that will do cyl. contribution test
I want to be free from dealer service and also need a supplier of reliable parts other then ford if that is possible
Old 10-23-2013, 11:15 PM
BLADE35's Avatar
You want an AE with Ford Enhanced or Like theres others but they probably cost more
Riffraff Diesel: AutoEnginuity Total Ford Enhanced Bundle
The injectors might be a waist they are spendy so most wait until they need them
Also your style HPOP do well so I wouldn't change it UNLESS it comes up bad with Diagnostic testing
With the DTC you have and year of truck probably just want to do the Normal STC--Dummey Plug--STandpipes I would Also go a step farther and Rering all injectors with the Alliant power Oring kits that have the Top inject oring where the HPO Rails goes into the Injectors and maybe even rering HPO Rail nipple cup orings as some of those start to fail with age now
At this point we need Numbers and need to rule out a Bad ICP sensor if that checks OK then Time to Air Test
Old 10-24-2013, 12:18 AM
ScanGauge II for your live gauges: You can walk into most AutoZones and they sell them. It will be the best money you ever spent on this truck $160.
Linear-Logic/ScanGaugeII with trip data computer, real-time display of operating conditions and scan tool (SG2) | ScanGauge | AutoZone.com
The AE, I purchased from Riff Raff. I ordered it on a Monday and it came in on Wednesday. Oregon to South Carolina. It was the best deal on the net. $359 and free priority 2 day shipping.
Old 10-24-2013, 12:13 PM
Thanks Blade 35 and 99expyproblems I will work on the scanner so I can get some numbers. Im in Norhern BC Canada so supply of these parts will be my goal today
Old 10-24-2013, 12:32 PM
Worse comes to worst, you can order it online through Amazon and have it shipped to Canada....
Amazon.com: ScanGauge II Ultra Compact 3-in-1 Automotive Computer with Customizable Real-Time Fuel Economy Digital Gauges: Automotive Amazon.com: ScanGauge II Ultra Compact 3-in-1 Automotive Computer with Customizable Real-Time Fuel Economy Digital Gauges: Automotive
Please Help with engine stalling Roscoe316 6.0L Power Stroke Diesel 28 10-21-2016 08:51 PM
way too confused, ipr icp or what? bbathey25 6.0L Power Stroke Diesel 21 08-23-2016 11:45 AM
Truck intermittently wont start specialpete2004 6.0L Power Stroke Diesel 5 08-28-2014 11:18 PM
2003 F250 6.0 P0280, P2617, P0281 kevbits 6.0L Power Stroke Diesel 4 02-22-2014 10:09 AM
6.0 rough run Fuel or Injectors ?? mcerchio 6.0L Power Stroke Diesel 14 06-04-2013 09:55 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
