Anyone know where I might find a replacement o-ring in the oil pump for my 1962 y-block? This is the one for the cover. I've tried the a few local auto parts stores as well as online catalogs. I don't really want to buy a whole rebuild kit just to get the gasket. I also tried the hardware store and Lowes, but have not found the correct thickness/diameter combination.
Thanks Bill I got to thinking when I posted thIs question if that might be an option. The only trouble asking Green (and similar companies), is the need for part numbers. Those are sometimes hard to come by for guys like me.
All you have to do is give the partsguy @ Green Sales the application and describe the part and they can look it up.
Everyone that answers the phone at Green is an ex-Ford partsguy, except for the lady that (I assume) works in the office.
And, you can look the part numbers up yourself with this: 1957/63 Ford Truck Parts Catalog available on a C/D from hipoparts.com
it is square, but I used a round one and it fit. Just be careful when you replace it because parts will just fall on the ground when you take the cover off.
