High idle mod? - Ford Truck Enthusiasts Forums
High idle mod?
Old 10-22-2013, 09:44 AM
atomicglock atomicglock is offline
atomicglock is starting off with a positive reputation.
High idle mod?
Real quick question on the high idle mod.
I don't have upfitter switches and, thanks to the previous owner, I can't install them either. Previous owner did put a toggle switch (I have no idea what it's for) in the dash to the left of the steering wheel.
Can I use this switch for the mod and, if so, what's the best way to wire it up?
Thanks.
Old 10-22-2013, 09:51 AM
jswartz84's Avatar
jswartz84 jswartz84 is offline
jswartz84 has a great reputation on FTE.jswartz84 has a great reputation on FTE.jswartz84 has a great reputation on FTE.jswartz84 has a great reputation on FTE.jswartz84 has a great reputation on FTE.
Sure can.
Locate a hot wire under the dash for your power and tie in to the PTO wire behind the fuse panel.
Old 10-22-2013, 11:08 AM
Thanks.
High Idle Mod ??? jdc228 6.0L Power Stroke Diesel 36 10-10-2016 12:41 AM
90 Model F 150 Idling fast dodgewade 1987 - 1996 F150 & Larger F-Series Trucks 12 04-09-2016 04:49 PM
Switch to fit adjustable pedal spot NotURMailman 1999 to 2016 Super Duty 9 01-11-2016 04:22 PM
High Idle during Remote Start w/o setting the parking brake Trash Hauler 6.7L Power Stroke Diesel 10 03-03-2015 06:44 PM
High idle mod i eat hybrids 6.0L Power Stroke Diesel 21 04-19-2010 07:48 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
