Head removal question
Old 10-22-2013, 03:52 AM
Ford4Life7.3's Avatar
Ford4Life7.3
Ford4Life7.3 is offline
In the shop pulling the heads. What order should i remove the factory head bolts in? Some say it warps heads by removing them in the wrong order, some say it dont matter. Id rather be safe. Just do them in reverse of head stud install order? Or different sequence?
Old 10-22-2013, 06:11 AM
427 fordman's Avatar
427 fordman
427 fordman is online now
I'd take them off any way you want Rob. I've removed countless heads off of motors and never once considered what order to remove the bolts. You aren't going to do any harm.
Old 10-22-2013, 06:28 AM
DIYMechanic's Avatar
DIYMechanic
DIYMechanic is offline
Yup. Doesn't matter what order you remove them in. Believe me, you're not going to warp those heads! Once you lift one, you'll see what I mean.
The torque sequence is more about compressing the head gasket correctly than it is about damaging the heads.
Old 10-22-2013, 06:57 AM
fordpride's Avatar
fordpride
fordpride is offline
Just my .02 but I believe if you pull a head you should take it to be resurfaced.
Some people don't and never have a issue. But the cost is to cheap compared to the time and aggravation of having to pull it again
Old 10-22-2013, 01:36 PM
Yawlie's Avatar
Yawlie
Yawlie is offline
Only time I have ever had an issue with torque sequence causing problems was when I was a teenager and and cranked em down starting on one end with a 'luninineeum head on an import.
In all my youthful wisdom I 'fixed' it with copious amounts old brown gasket-goo....
I tend to like to crack em loose from center out, but have not had an issue with heavy heads like your talking about.... but Im still gun-shy ...ish...
Old 10-23-2013, 08:41 PM
fordman67's Avatar
fordman67
fordman67 is offline
They sure am not gonna warp from pulling them.
Mike is spot on..always resurface! Its not worth going with out
Old 10-24-2013, 12:23 AM
Ford4Life7.3
Well im taking them to my machine guy to have the valve seals done, as well as cleaning them along with the oil pan, front cover, and a few other odds and ends.
jacob_powerhouse
09-10-2010 02:00 PM
satwood
12-29-2009 09:07 AM
sturoe
09-25-2007 07:18 PM
79_ford_400_guy
05-13-2003 07:02 AM
FordOffRoader
04-25-2002 05:57 PM
Quick Reply: Head removal question
