240 cid timing gear
240 cid timing gear
I have a '74 f100 with an old i6 240. I need to replace the timing gear. On this motor it uses a gear to gear connection( no chain) i had no problem getting the small metal gear( crankshaft gear) off. But am unable to get the camshaft gear(the larger one) off. Being that it is some type of plastic material all a puller does is rip through it. Any ideas? Also the new gears ate both steel. Any install suggestions?
zaktpl
07-24-2019 08:43 AM
Mr.Pistolero
18
06-20-2015 10:09 AM
