Squeaky sticky clutch pedal
Old 10-21-2013, 07:46 PM
mcguire87's Avatar
mcguire87
mcguire87 is offline
Ok, I bought a 96 f150 for 500$ that had been sitting for 5 years. I've put some time and money into it and its all set for the road now. Only problem being after a few mins of driving the clutch gets sticky and squeaks. When I first bought it, it was sticking bad and has kind of improved slightly to where it's at now. I can't feel or hear anything in the master cylinder, I can however hear it in the bell housing. Would this just be a throwout bearing? Rust build on the shaft? Slave sticking after sitting for so long? I'm dropping the trans on Friday, just wondering what I should purchase. Throwout for sure.
Any input will help thanks
Old 10-21-2013, 07:48 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
Drive it till it stops. Otherwise you will be dropping the trans to do it
Old 10-21-2013, 08:03 PM
mcguire87's Avatar
mcguire87
It's not something I seen as fixing itself, I am dropping the trans this coming Friday
Old 10-21-2013, 08:13 PM
kermmydog's Avatar
kermmydog
kermmydog is offline
If your dropping the trans & plan to keep & drive this you might as well replace slave, T/O, clutch, disc, & master cylinder.
The other option would be to try & spray some Deep Creep or a good Teflon spray through the clutch fork hole in the bell housing & see if that helps, if memory serves me the slave & T/O bearing are one unit that slide on the trans collar.
Old 10-21-2013, 08:40 PM
mcguire87's Avatar
mcguire87
Ok, I will have a look at the clutch while I'm in there, I found receipts saying it was done in 04 and wasn't driven after 08 so I would hope it's still good, never know though. I did spray some creeper in the inspection hole on the housing. Didn't seem to help any
Old 10-21-2013, 09:39 PM
kermmydog's Avatar
kermmydog
Smile
My guess is a new T/O bearing. I'm not sure if they are sold separate or you have to buy the unit of slave & T/O. never looked it up.
Just looked on O Reillys website the slave cyl & clutch release bearing assembly, as they call it is $49.99, just the bearing is $61.99.
Old 10-21-2013, 10:00 PM
mcguire87's Avatar
mcguire87
Wow, pretty big difference, my local parts store was 84.00 just for the slave, and 60 or the bearing, have to do some searching. Most parts I've purchased I got from ford ad they seem to be cheapest price wise. Hopefully it is just a t/o.
I appreciate the fast responses
peter_x
08-14-2012 01:50 PM
powersmoked
1983 - 2012 Ranger & B-Series
09-26-2010 05:36 AM
skipr
11-15-2009 10:02 AM
covrace
05-03-2004 01:26 PM
Quick Reply: Squeaky sticky clutch pedal
