1.0 Exhaust Housing - Ford Truck Enthusiasts Forums
1.0 Exhaust Housing
Old 10-21-2013, 05:26 PM
DHamSTER's Avatar
DHamSTER DHamSTER is offline
DHamSTER has a good reputation on FTE.DHamSTER has a good reputation on FTE.
1.0 Exhaust Housing
Hi guys,
I have a big project ahead of me next spring and I am curious what you guys think. Obviously with a bigger exhaust housing comes performance increases.
I have two options in mind.
1. BD-Power 1.0 A/R Turbine Housing, my money saver option.
BD-Power 1.0 A/R Turbine Housing 1047005
2. Garrett 1.0 A/R Wastegated Exhaust Housing
Riffraff Diesel: Garrett 1.0 A/R Wastegated Exhaust Housing
I just want to know if saving 50 bucks is going to worth it or go with the big name Garrett.
Old 10-21-2013, 05:42 PM
SkySkiJason's Avatar
SkySkiJason SkySkiJason is online now
SkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant future
For the money, I'd get a van turbo with 1.15 exhaust housing. Rebuild and paint, then sell the stocker and you'll come out really good! The good folks on CL will give ya $400 if ya dont mind asking.
Check car-part.com for a van turbo near you. Usually find'em under $300...
Old 10-21-2013, 05:43 PM
DHamSTER's Avatar
I would go van turbo but thats not what I want my build to be. I want to have a stock compressor side and stock injectors. Im just trying to make make stock move a little bit fast than everyone else.
Old 10-21-2013, 05:49 PM
DHamSTER's Avatar
That site won't let me search parts without my VIN#, Ill pass.
Old 10-21-2013, 07:20 PM
Quote:
Thats not correct. You search by make model year and your zip code... Ive been using it for years.
Old 10-21-2013, 07:33 PM
A 1.0 housing isnt gonna do much for ya there... At best it'll reduce drive pressure a little and help surge.
I ran the van turbo and stock sticks in my X. It was a very good combo that towed a 12k lb Toy Hauler like a boss and laid down 324hp on the dyno. The rebuilt van turbo was $400, outlet adapter $100 and $10 for the VHT paint. I sold my +300k mile stocker for $175 (to a friend) and later sold the van turbo for $400 needing a compressor wheel.
Since ya seemed concerned about $50 - I thought I'd share some numbers with you.
Old 10-21-2013, 07:36 PM
DHamSTER's Avatar
So you spent money on a van turbo and outlet, selling your stock turbo, eventually selling your van turbo..... for a compressor wheel? I don't see how you made out on top.
Anyway. Does anyone else have an opinion besides a van turbo, an opinion on something in this post?
Old 10-21-2013, 07:37 PM
DHamSTER's Avatar
$50 may not be much to you, but a guy on a budget that matters, which is why I asked if saving 50 bucks is worth it with this option for my build.
Old 10-21-2013, 07:52 PM
JT250's Avatar
JT250 JT250 is offline
JT250 has a good reputation on FTE.JT250 has a good reputation on FTE.JT250 has a good reputation on FTE.
I have no experience with either of the housings .
If I remember correctly Jason sold his van turbo and went with the bigger S366 T4 style turbo. He just said that the van turbo needed a new wheel when he sold it.
Old 10-21-2013, 08:06 PM
BWST's Avatar
BWST BWST is offline
BWST has a good reputation on FTE.BWST has a good reputation on FTE.BWST has a good reputation on FTE.
Not sure a 1.0 housing will add performance with stock sticks and stock tune (no tunes right?)
I'm toying with adding the 1.0 garrett housing when I upgrade sticks, but until then, the stock turbo 0.84 housing handles things pretty well - EGT stays inbounds.
You might trade some spoolup with a larger exhaust housing and no added fuel. Will that be ok?
I put on the ATS compressor housing to cure the surge I was having with tunes, and it seems to give enough air - about 27psi in 60e and just a little grey smoke (I think we're calling it haze).
Riffraff's ported housing wheel may go along way to adding the needed air bigger sticks need, but might also help clear up the haze with the stock sticks.
Old 10-21-2013, 08:08 PM
DHamSTER's Avatar
Sure, a van turbo is a better option for stock sticks but thats not why I posted this.... Im looking to run a stock turbo and stock sticks, so Im looking for a better option on exhaust housings for this turbo.
Im just trying to make this turbo perform the best that it can.
Old 10-21-2013, 08:12 PM
DHamSTER's Avatar
My plan is to eventually get Beans tunes, But that chip will come shortly after my exhaust work. Some fuel mods will follow the chip. So I have a plan to counteract those performance losses running no tunes for a short period of time.
But yes it is okay to have some minor spool up loss until I finish my build.
Im really just looking for which of those housings are better. I mean they are identical, does it just come down to price or is there something that will have a huge effect in the long run?
Old 10-21-2013, 08:31 PM
DHamSTER's Avatar
Quote:
That housing actually did wonders for my buddy, Diehardstroker, that was his first mod after his tuner. Im actually shooting for the Riffraff 6/6 wheel, the housing, and a high flow outlet, and a bighead wastegate.
That's my turbo work before the tuner.
Old 10-21-2013, 08:36 PM
diehardstroker's Avatar
diehardstroker diehardstroker is offline
diehardstroker has a good reputation on FTE.diehardstroker has a good reputation on FTE.
a lot of these housings are personal taste, some want more top end which would get the job done with a 1.15. some love the stocker, with super quick spool but runs out at of oomphh about 2500 rpms, for me personally and from what Dylan (DHamSTER) and I have talked about, the 1.0 is a good option for middle ground, sure it wouldnt spool like the .84 but itd spool better than the 1.15 while still giving you a better top end than the .84, and slightly less top end then the 1.15. so youve got the best of both worlds.
Again IMHO it really depends on what the owner wants. Im also curious if anyone has anything bad to say about the BD housing as sometime in the future (after i get my transmission sorted out) id like to get a 1.0 housing.
Old 10-21-2013, 08:39 PM
DHamSTER's Avatar
Exactly, I haven't heard or read any reviews on the BD housing. Why spend more money when you don't need to.
SO if anyone can clear up why the BD is or isn't a good idea that would be appreciated.
1.0 A/R vs .84 A/R w/ ZF6 manual transmission? Sous 1999 - 2003 7.3L Power Stroke Diesel 89 09-29-2016 04:06 PM
OEM PSD Turbo specs, upgrade options, and user feedback Bigdaddybus 6.0L Power Stroke Diesel 9 02-08-2012 06:29 PM
Turbo Tech for Dummies BlueOvalBud Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 13 12-26-2010 05:47 PM
Converting Stock Turbo to Van Turbo with 1.15 AR Motoxman_117 1999 - 2003 7.3L Power Stroke Diesel 19 03-22-2009 02:50 AM
What model Garrett turbo... telfari 1999 - 2003 7.3L Power Stroke Diesel 3 09-15-2003 09:55 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
