1.0 Exhaust Housing - Page 5 - Ford Truck Enthusiasts Forums
1.0 Exhaust Housing
  #61
Old 10-22-2013, 07:23 PM
SkySkiJason's Avatar
SkySkiJason SkySkiJason is offline
SkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant future
He will get what he is after and he'll be happy about it. The difference here is splitting hairs and the butt dyno always favors the anticipated results.
I've said why I didnt think it was a good plan as far as economics vs performance, but I don't have any reason to argue about it.
Let us know how ya like it hamster!!!
  #62
Old 10-22-2013, 09:32 PM
Stewart_H's Avatar
Stewart_H Stewart_H is online now
The Nekkid Super Mod
Stewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputation
Quote:
Originally Posted by SkySkiJason View Post
I know someone who went from stock to 1.0 housing with stock injectors, maybe that's the guy you want to hear from.
I'm one of those guys. And like I posted earlier when I agreed with your statement, I saw no performance gains. And like your statement that I agreed with, I did it as a preventive measure against surge happening while towing my travel-trailer.
Stewart
  #63
Old 10-22-2013, 10:17 PM
JT250's Avatar
JT250 JT250 is online now
JT250 has a good reputation on FTE.JT250 has a good reputation on FTE.JT250 has a good reputation on FTE.
I feel that this is now going nowhere. Nobody has an answer to your original question and it seems like you already have your mind made up anyway.
I'm sure PHPs test was done on a stock turbo. Those numbers aren't surprising. A 1.15 on a stock turbo makes no sense to me.
Sorry we couldnt help. In the future be aware that people are Sharing their opinions and it is best not to take things personally.
  #64
Old 10-22-2013, 10:36 PM
mueckster's Avatar
mueckster mueckster is offline
aka Redneck Wrencher
mueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputation
I ran an ATS 1.0 turbine and ATS ported compressor housings with a stock wheel on my stock turbo. I really loved the combination with stock injectors and tuning. Nice spool up and slightly lower EGTs. I sold it to another member who was equally as pleased. I'm sure with a billet wheel, it would have performed even better.
IMHO, there is no "voodoo" when it comes to like sized turbine housings. I would go with the best value.
  #65
Old 10-22-2013, 10:39 PM
DHamSTER's Avatar
DHamSTER DHamSTER is offline
DHamSTER has a good reputation on FTE.DHamSTER has a good reputation on FTE.
Thank you man!!! The best answer I have gotten in the last 2 days! Your opinion is exactly what I was looking for!
  #66
Old 11-18-2013, 09:47 PM
cookie88's Avatar
cookie88 cookie88 is offline
cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.
Quote:
Originally Posted by DHamSTER View Post
Im not getting something thats nonwastegated...
Spoken like someone who really doesn't understand all of this yet... Good luck!
Please elaborate then....
It's pretty simple. A stone stock turbo can make 30 psi all day every day for years on end. 30 psi is also well below what the engine can handle. So if you're not damaging the motor and your not damaging the turbo then what is the purpose of the wastegate? The answer is nothing. All that open wastegate is doing is making the turbo less efficient by bleeding off drive pressure that could otherwise be put to the ground.
I do tend to agree that the 1.0 housing is the best "All around" housing for stock or mild sticks and a chip... but again.. the wastegate question is neither relevant, or needed.
One thing that nobody has pointed out is that you may end up pretty disappointed with your new set up. When you install larger housings and split profile wheels you are setting that turbo up to either handle extreme drive pressures, or to stay cool towing heavy...... but with stock tuning and stock sticks your new big turbo will be a dog. It will take forever to spool and your boost numbers will be far below what you expect. You simply won't have the drive pressure to make use of the big slow turbo.
Once you plug in the hot rod tuning the modded turbo will shine..... but stock vs. stock the .84 turbine and stock wheel will kill your modded turbo.
1.0 A/R vs .84 A/R w/ ZF6 manual transmission? Sous 1999 - 2003 7.3L Power Stroke Diesel 89 09-29-2016 04:06 PM
OEM PSD Turbo specs, upgrade options, and user feedback Bigdaddybus 6.0L Power Stroke Diesel 9 02-08-2012 06:29 PM
Turbo Tech for Dummies BlueOvalBud Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 13 12-26-2010 05:47 PM
Converting Stock Turbo to Van Turbo with 1.15 AR Motoxman_117 1999 - 2003 7.3L Power Stroke Diesel 19 03-22-2009 02:50 AM
What model Garrett turbo... telfari 1999 - 2003 7.3L Power Stroke Diesel 3 09-15-2003 09:55 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
