Block Heater - Ford Truck Enthusiasts Forums
Block Heater
Old 10-21-2013, 12:59 PM
cortec cortec is offline
cortec is starting off with a positive reputation.
Block Heater
I have a 2011 F-150 with a 5.0 V8 and am in need of a block heater. Who makes an aftermarket heater that can be installed in this truck. I expect to see lows as low as -50.
Old 10-21-2013, 01:15 PM
Turbo Dog's Avatar
Turbo Dog Turbo Dog is offline
Turbo Dog has a good reputation on FTE.Turbo Dog has a good reputation on FTE.Turbo Dog has a good reputation on FTE.
I used one of the lower radiator hose style heaters on my older truck...it didn't do anything but warm up the area around it. The engine and radiator didn't warm up.
So I would suggest only using the stlye the goes into one of the freeze plugs...might even need one per side.
Old 10-21-2013, 01:21 PM
meborder's Avatar
meborder meborder is online now
meborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant future
Welcome to the forum!
I'd take a good look behind the front bumper, you should have one. the 5.0 is e85 compatible and one should have been installed as standard equipment.
if, for some reason, you do not have one, i would go to the ford dealer to get a factory unit. you would be hard pressed to find one of better quality in the aftermarket.
back when i sold parts we sold "Kat's" brand heaters, and they were very good, but i from what i can tell the factory units are quite a bit better.
good luck.....
-50 ... brrrr.
i've gone to work in -29, and that was cold enough .... -50 -- yowza!!!!
Old 10-21-2013, 01:23 PM
sammy77's Avatar
sammy77 sammy77 is offline
sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.
Depending on where the truck was sold, you may have one already. Why not purchase from Ford? On the 5.0, I have heard of the install involving dropping the front axle.
Old 10-21-2013, 04:40 PM
ddbck's Avatar
ddbck ddbck is offline
ddbck is gaining momentum as a positive member of FTE.
It should be $180 - $230 for the part & install at dealership. The aftermarket heater plugs are ok but a bitch to put in. The OEM heater is better. If it stays that cold you should think about a "Husky heater pad" as well. I had them on the oil pan & tranny on my diesels. we get sustained cold here in Wyoming too.
Need engine block heater advice 2gumby2 2015+ F150 11 04-06-2016 12:30 PM
Block heater mudguts Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 7 11-21-2015 05:30 PM
block heater - trickle charger combo? ZekeD 1999 to 2016 Super Duty 5 02-28-2012 11:26 AM
Block Heater Power Consumption cowmilker08 1994.5 - 1997 7.3L Power Stroke Diesel 21 02-15-2012 11:47 PM
Block Heater Watts QUINCE 6.0L Power Stroke Diesel 3 11-06-2008 11:40 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
