won't start without pressing pedal to floor - Ford Truck Enthusiasts Forums
Old 06-24-2002, 10:35 AM
danpiscotty danpiscotty is offline
danpiscotty is starting off with a positive reputation.
I have a 92 ford F150 302. Everytime I try to start the truck I MUST push the gas pedal to the floor in order to get the thing to start. it is fuel injected. This has always been the case since this engine has been replaced. I'm not sure where the problem lies. I do hear the pump turn on then off. It will not start by just turning the key at anytime. I'm not a firm believer in it being the filter since it will idle. It could be a pressure regulator but I'm not fully convinced nor do I want to just start replacing items until it's fixed. It could possibly be some other issue that I'm not familiar with.
Any ideas?
Sincerely,
Dan
Old 06-25-2002, 11:32 AM
I guess I've solved my own problem.
It turned out that the temp sensor was defective and open (high resistance around 12 meg!). The resistance of the new thermistor for the truck was around 24k ohms at around 80 degrees.
When you push the accelerator to the floor you turn off the injectors. Since the old temp sensor was open, it was simulating a cold start of around -40 degrees thereby enriching the mix with a lot of fuel. Since the injectors dumped so much fuel, I needed to depress the accelerator to the floor to clear out the fuel in order to start the truck.
16 dollar problem solved!
Old 06-25-2002, 12:49 PM
winfordr's Avatar
winfordr winfordr is offline
winfordr is starting off with a positive reputation.
That is about the most useful piece of info I have seen here in a while. How did you determine that it was the temp sensor? Did you get a code, a hunch, or what?
Where is the temp sensor located?
Winford
Old 06-26-2002, 02:34 PM
Thanks for the complement. Actually, I asked a mechanic friend about the problem and he said that the f150's have this common problem. I don't know if I agree with that since it's a simple thermistor and they are very robust. I was at a crossroads when he suggested the temp sensor. It made sense on why it could be that and guess what, he was right! I actually had gone through changing the timing chain, spark plugs, rotor, distributor cap, and ignition coil before getting to the temp sensor. These problems helped nail it down.
Old 06-26-2002, 02:44 PM
Old 05-31-2016, 12:52 PM
Jim Bohrman's Avatar
Jim Bohrman Jim Bohrman is offline
Jim Bohrman is starting off with a positive reputation.
I have this same problem on my 92 Ford F150 XLT - sounds like a possible solution, will look into it! Thanks
Old 05-31-2016, 10:58 PM
'89F2urd's Avatar
'89F2urd '89F2urd is offline
'89F2urd has a good reputation on FTE.'89F2urd has a good reputation on FTE.
Epic first post 14 year old thread revival. Crazy, I was 16 when the last guy posted!
Old 06-03-2016, 12:00 PM
I like epic, fits me. lol
why do my brakes need pumping to build pressure? help Ranger1979 1973 - 1979 F-100 & Larger F-Series Trucks 28 07-03-2016 11:38 PM
Diagnosing Brakes / Master Cylinder with Low Pedal AL` 6.0L Power Stroke Diesel 19 02-17-2016 02:54 PM
1992 Ford F350. Brake Pedal Goes to Floor on Sharp Left Turns Only AmericanIron460 1987 - 1996 F150 & Larger F-Series Trucks 12 10-20-2015 03:56 PM
2005 ford escape...air in brake system?? Brass77 Brakes, Steering, Suspension, Tires, & Wheels 0 05-04-2014 08:26 PM
96 ford f-150 starting problems jwilliams777 1987 - 1996 F150 & Larger F-Series Trucks 3 05-14-2002 07:13 PM
Tags
2004, 88, accellerator, accelorator, bogs, car, f150, floor, ford, forum, gas, pedal, press, pressing, start, starts, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
