Slight Engine Stumble
Old 06-16-2019, 06:13 PM
Roger T. Pipe's Avatar
Roger T. Pipe
Roger T. Pipe is offline
'93 5.0 A/T 4x4...when I'm at a light in Drive, foot on the brake, I detect a slight engine rough running. NOT enough to even make the tach flutter, but I know they're unreliable as far as this goes. Any ideas on where to start looking? Engine is all-original 79K ...pretty well maintained. TIA!
Old 06-16-2019, 07:09 PM
rla2005's Avatar
rla2005
rla2005 is online now
Received 1,157 Likes on 915 Posts
Spark plugs, wires, cap and rotor age?
If you replaced the above, were the wires routed properly to prevent crossfire?
Old 06-16-2019, 07:23 PM
Roger T. Pipe
Yes, plugs, wires & rotor were all done about 1.5 years ago....I *think* I may have actually found the culprit...Over the HVAC plenum (pass side of engine) there is a broken 'T' fitting and the hose is just dangling...it's a tiny hose, but it's a vacuum leak all the same.....I know these fittings have the durability of a soap bubble after 20 + years so I'll get to replacing them. Any good source for those?
Old 06-16-2019, 08:40 PM
torq'ta 5 8's Avatar
torq'ta 5 8
torq'ta 5 8 is offline
do them one at a time, less headache, bronco forum tells you what sizes and length
Silicone Boost/Vacuum Hose
Replace Plastic Vacuum Hoses with Rubber - Ford Bronco Forum
p.j.
36
02-10-2007 05:29 PM
Broncobudy
1978 - 1996 Big Bronco
02-07-2007 05:01 AM
jonathandennell
12-30-2006 07:21 PM
Wangert
11-21-2005 05:37 PM
Nightrain
07-14-2004 03:06 PM
Quick Reply: Slight Engine Stumble
