Door Tag Encoding
Door Tag Encoding
My '64 Highboy didn't have a warranty plate or title when I bought it. To simplify the title application process, I need to get a door tag from Marti.
The vin is F26JK447798.
The truck has/had:
4.56:1 Gears
Dana 60 open rear
Dana 44 open front
T98 transmission
Platform and stake body (or whatever it's called)
120" wheelbase
not a custom cab
dark green interior and exterior (I don't know anything about the seat)
Can you all fill in the blanks for the door tag?
As for the model, couldn't you it be F260, F261, or F262 or was that only later years?
The truck has/had:
4.56:1 Gears
Dana 60 open rear
Dana 44 open front
T98 transmission
120" wheelbase
not a custom cab
My '64 Highboy didn't have a warranty plate or title when I bought it. To simplify the title application process, I need to get a Warranty Plate from Marti.
F26JK447798
120" wheelbase
dark green exterior L = Holly Green
Model F260 = F250 4WD, 6800 lbs. GVW
dark green interior (I don't know anything about the seat)
Body 381: 3 = Medium Green Crush Vinyl & Medium Green Rib Vinyl / 81 = 81A Standard Cab.
Trans F = Warner T-98
Axle 24B: 24 = Spicer 60 Rear Axle / 4.56-1 / No Limited Slip / 5,200 lbs. Rear Axle Capacity / B = Spicer 44-6F Front Driving Axle / 4.56-1 / 3,000 lb. Front Axle Capacity.
MAX GVW LBS 6800
CERT NET HP 114
RPM 3600
DSO ?? Ford District Sales Office, where the original selling dealer ordered the truck from. (pick one from the chart).
F26JK447798
120" wheelbase
MAX GVW LBS 6800
CERT NET HP 114
RPM 3600
51MHF5
07-22-2013 09:15 PM
