Where can I get bigger injectors?
I have a 96 f250 mostly stock but a cold air intake. What engine can I find ih high output injectors off of? I can get my hands on used engines and was wondering what would have bigger compatable injectors for my 7.3. Looking to up the boost and power of my truck.
Pretty sure you'll need to change your PCM too with the split shots.
Stage 1's at rosewood's will run you around $500. That price is for 160 cc budget injectors.
Price can go up depending on the condition of your core injectors.
Rosewood Diesel Shop
Thanks that's what I was looking for. Can I go higher then 10k safely? Will it continue to make a difference or is there a limit? Also off topic here but I have the small spectra air filter (k&n type) that the truck came with. I will go bigger but do you think it is restricting air flow? I'm thinking so.
Holy crap. I added a 17.5k ohm resistor and pulled the pancake pipe off my turbo and dam I got some extra power. I can do burn outs and my truck pulls really hard through first and second gear...than falls on its *** in third. No boost after third and it feels like its missing. Did I over do it with 17k? My fuel is up to 80 maybe 90 psi. The truck is running great until third gear. Any ideas? What would cause power loss only after third. Its an auto trans. I almost want to say it was popping and stumbling.
