How loud is a 460 with straight pipes and headers? - Page 2 - Ford Truck Enthusiasts Forums
Old 10-20-2013, 06:08 PM
97puller's Avatar
97puller 97puller is offline
97puller is starting off with a positive reputation.
I had about 2 feet of pipe and a turn down after the big stock cat on my '97 460 I wasn't too loud. I took the cat out and put a 3in magnaflow muffler in its place I think the muffler is actually louder.
Old 10-20-2013, 07:45 PM
Skip1970's Avatar
Skip1970 Skip1970 is offline
Skip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputation
i like them weldup headers you can make the exhaust come right out the top of the hood. put packs on the end, and cant get no simpler then that.
Old 10-21-2013, 03:31 AM
wyoming4x4's Avatar
wyoming4x4 wyoming4x4 is offline
wyoming4x4 is gaining momentum as a positive member of FTE.wyoming4x4 is gaining momentum as a positive member of FTE.
loud!
police escort for sure! So loud i could see flashing lights. Ha! Ha! true story!
Old 10-21-2013, 05:01 PM
NidStyles NidStyles is offline
NidStyles is starting off with a positive reputation.
Thanks everyone for the replies.
Not too sure about the exhaust through hood thing being something I want to try. If it were a dedicated off-road truck then sure, but I have to drive through a lot of highway before that off-road. I also drive through some to go play in the desert here.
I live in Arizona, and try to avoid California, but if I have to go there ever I would rather not have exhaust pipes sticking through the hoods melting the safety layers of my windshield. :-P
Something tells me that the CHP would love me for that. I doubt they will love me driving with nearly open headers, but I can mitigate that by not driving like a country boy in a mud hole to stay off their radar as much as possible. They only positive thing is that the truck isn't lifted, and I run street tires until I get to the trails where we hunt. So it looks like a work truck for the most part.
Old 10-21-2013, 06:29 PM
slashfan7964's Avatar
slashfan7964 slashfan7964 is offline
slashfan7964 is gaining momentum as a positive member of FTE.slashfan7964 is gaining momentum as a positive member of FTE.
I think a good compromise would be cutouts. Open headers at a flip of a switch and quiet when it needs to be.
Old 10-22-2013, 03:10 PM
iggybob44's Avatar
iggybob44 iggybob44 is offline
iggybob44 has a brilliant futureiggybob44 has a brilliant futureiggybob44 has a brilliant futureiggybob44 has a brilliant futureiggybob44 has a brilliant futureiggybob44 has a brilliant futureiggybob44 has a brilliant futureiggybob44 has a brilliant futureiggybob44 has a brilliant futureiggybob44 has a brilliant futureiggybob44 has a brilliant future
Wont having a really loud exhaust be a disadvantage when hunting? Ive got a 77 with a 460, stock exhaust manifolds and some sort of glass packs, and its fairly loud as it sits. personally when i 4 wheel i want to be able to easily hear more than an exhaust, things like tire spin, or noises within the entire driveline
Old 10-22-2013, 10:33 PM
Quote:
I don't hunt from the truck. LOL!
I'm not worried about hearing anything else. If it starts making funny noises there is nothing I can do about it until I get out of the woods. The only thing I travel with are fluids, tire chains, a tug cable, and belts. If something is making a noise that means there is something wrong that I will not be able to fix with my socket set and fluids. The E4OD is already a noisy beast.
Old 10-22-2013, 11:56 PM
iggybob44's Avatar
Im not suggesting that you hunt outta the truck, but as you approach hunting grounds arent you dealing with animals that possess far better hearing than humans? as such, isnt announcing your presence with a louder than necessary vehicle putting you at a disadvantage?
Old 10-24-2013, 12:50 AM
I only use the truck to pull and carry the carcass. I park the truck and walk in.
Old 10-26-2013, 03:30 PM
iggybob44's Avatar
Noises often times start off as a warning........adding a little fluid, or tightening a bolt when the sounds first occur can prevent worse damage or an actual breakdown..But if you dont care about how loud your truck is, i certainly dont either! Im hundreds of miles north of you. It seems as if you really werent interested in others opinions, only looking to argue. Even the question is kinda silly, since any internal combustion engine without much exhaust is loud, whether its a 460 or a 50cc Stihl Chain Saw.........
Old 11-04-2013, 04:23 PM
Actually, you seem to be the one arguing or having an issue with it. I was asking how loud, not if it were too loud for you to be comfortable with. There is a distinctive difference in the two. One is something measurable and quantifiable, the other is your opinion and prone to subjective variance depending on what time of the day and how well hydrated you are.
It was the other members of the site that took it upon themselves to mingle the two and be abusive with their tone and outright disrespectful. I was never disrespectful, but I did respond in kind.
Have a nice day sir, and I hope you future efforts are just as prosperous and positive as your current ones.
If you want to know I solved the problem. Open headers were not that loud, I drove it around for a week like that, and with a full dual exhaust the truck actually sounds nice.
Old 11-05-2013, 09:19 AM
fasthauler's Avatar
fasthauler fasthauler is offline
fasthauler is gaining momentum as a positive member of FTE.
Wicked Flow Mufflers
I have been running Wicked Flow straight thru mufflers on my 77 for years. They dump out under the truck and the noise is minimal except when driving in a closed area. It is fun driving through a parking garage. I set off every car alarm in the garage.
  #28
Old 11-05-2013, 11:48 AM
iggybob44's Avatar
Well then you answered the question to your own satisfaction............."Open headers were not that loud" "And with a full dual exhaust the truck actually sounds nice" These are hardly numbers, nothing quantified. Equipment required to measure decibel level is not the sort of thing that most of us possess, i suspect the vast majority of us dont consider purchasing it for the very simple reason that we are able to ascertain that it will be too loud for OUR own tastes, not to mention that it might get us unwanted attention from the local LE.
Did you honestly expect someone to give you actual decibel levels?
And Best luck to you, your vehicle and in your travels, sir.
  #29
Old 11-05-2013, 02:48 PM
meborder's Avatar
meborder meborder is online now
meborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant future
i've got a dB meter if someone is willing to pay for all the exhaust work required to quantify numbers.
any takers?
beyond that, it is all subjective.
i drove my plow truck on and off the trailer with open headers and qualified it as "unbearable" and that is just a SBC ... no way would i try that with a 460.... but, to each his/her own.
i'm glad you are happy with your exhaust.
i do wish you would have done what you wanted everyone else to do, though ... that way we could all have numbers to reference.
  #30
Old 01-04-2014, 07:10 AM
winginit's Avatar
winginit winginit is offline
winginit is starting off with a positive reputation.
Quote:
Originally Posted by 85e150six4mtod View Post
Well, I took my a-hole pill yesterday, so let me try again.
I hear you about stuff that rusts or gets torn off--waste of time and money.
As for the magazine, I did find several other things with about the same numbers they post, but yea, they want the ad revenue and they want to sell mags.
My neighbor has Doug Thorleys on his 460 F350 and they do not seem to hang down too low. Not cheap through, but they are CARB approved, something he has to deal with in Ca. They work with all the sensors and cats.
Magnaflow has some big straight through stainless mufflers for their off road systems. Probably a fortune to buy.
MagnaFlow Performance Exhaust - Off Road Pro-Series
You can probably find something similar that will tuck up out of the way for less, maybe like so--3" in and out:
MagnaFlow Exhaust Part 18129 - Glass Pack Muffler - 4 Wheel Parts
No square edges to catch on stuff.
Good luck with it.
I have that Magnaflow off road pro series muffler in a 1991 jeep. If you Want it loud this is NOT the muffler for you. BUT it does tuck up nice out of they way. Will
Exhuast Cisneros100 Modular V8 (4.6L, 5.4L) 5 06-23-2016 09:09 PM
400 exhaust help DirtyLarry 1973 - 1979 F-100 & Larger F-Series Trucks 6 02-12-2015 08:09 PM
6.0 muffler delete 6ohpowerstroke 1999 to 2016 Super Duty 4 11-22-2014 06:59 AM
2001 f250 v10 exhaust Spearman25 1999 to 2016 Super Duty 0 05-23-2014 08:31 AM
loud exhaust........... saltbranch 6.2L V8 12 04-19-2014 04:41 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
